1600 turbo build thread
Moderator: seabeebuggy
buguy
Re: 1600 turbo build thread
Post by buguy » Mon Jun 11, 2018 10:02 pm
I just don't want to get compression so high I will only be able to run 5 psi of boost
rubenski
Post by rubenski » Mon Jun 11, 2018 10:54 pm
Will be lazy off boost then...
Better a little more like clone says and fab in an intercooler or watermeth injection...
buguy
Post by buguy » Tue Jun 12, 2018 5:56 am
I would only be able to that if I go through with the blow through conversion.
madmike
Post by madmike » Tue Jun 12, 2018 7:50 am
You'll be fine up to 8:5 on premium :wink: mine starts to ping @12lbs. :lol: then I add some 110 race fuel
buguy
Post by buguy » Tue Jun 12, 2018 10:15 am
I'd be ok with 12 pounds. I about pooped feeling 11 pounds for 2 seconds!
Post by Chip Birks » Tue Jun 12, 2018 1:16 pm
We've all said that...
Now I'm gonna see if I can't get my little engine up to about triple that...
Its a slippery slope.
buguy
Post by buguy » Tue Jun 12, 2018 2:21 pm
Haha!
Speaking of slipper slope.... I called Tim's today and to get my chamber volume where I need it I would have to get them ported. $670 for the pair. Owch. What other option so I have? Overtly large deck height? Find a stockish head closer to the cc I need? I'm going to use 92mm bore.
buguy
Post by buguy » Tue Jun 12, 2018 2:28 pm
Wait! I miscalculated. The chambers on the Tim's heads are 57cc as cast. That would put me right at 8:1 compression with. 048 combustion chamber. That's better. They are $207 and I think another $20 to open them up to fit the 92 barrel each.
Post by Chip Birks » Tue Jun 12, 2018 4:48 pm
You seem really stuck on that .048 deck height. Is that what you currently have or something?
madmike
Post by madmike » Tue Jun 12, 2018 5:34 pm
Don't be afraid to run big deck ,, check what the Red Baron runs :lol:
buguy
Post by buguy » Tue Jun 12, 2018 5:52 pm
No it's just kind of a middle ground.
Everything I've read says a tight deck is better.
Post by Chip Birks » Tue Jun 12, 2018 8:33 pm
Its mostly about clean burn, cool running and efficiency. Red Baron doesn't care about fuel mileage, or cool running.
madmike
Post by madmike » Wed Jun 13, 2018 5:44 am
mine has .120 :lol: runs cool and 28 mpg with a 750 Demon :lol: doubt it burns clean though :roll: :lol:
buguy
Post by buguy » Wed Jun 13, 2018 6:01 am
My guy checked out the case and it is good to go without a line bore. So I guess I will order my pistons today. Really been struggling with what pistons to buy. AA are obviously quite a bit cheaper but everything says to get Mahle. Clone is having good luck with his but can I get a tune as spot on as him with a carb?? Maybe if I keep boost low until I get a better ignition system I will be ok.
I think I'm going to get a W100 cam ground on 112 lobes and maybe spring for some solid rocker shafts too. Maybe!
buguy
Post by buguy » Wed Jun 13, 2018 6:05 am
.120 and your still at 8.5:1?? Dang!
I think having the engine hanging way out in open air helps us keep things a bit cooler.
I've been doing some searching and reading and came across this from here last night. Thought it was interesting. viewtopic.php?t=102753
