My draw through turbo
sideshow
Re: My draw through turbo
Post by sideshow »
Probably power brake vacuum source.
advinnie
Post by advinnie »
Cheers mate I’ve still not found out what the hole is for but I will continue looking 😁
buguy
Post by buguy »
Have you taken the plug out to see if it's just open to the manifold? If it is then it's simply a vacuum source.
Post by Chip Birks »
Definietly not preheat there. Thats usually under the manifold. Looks like a hole for a temp sensor, or water injection or something.
advinnie
Post by advinnie »
Took the plug/bolt out and it’s just a straight hole that goes into the manifold air stream
advinnie
Post by advinnie »
Here’s a link to the latest video of my 1600 draw through turbo bug now I’ve replaced the broken piston and cylinder and now with a slightly different exhaust
https://m.youtube.com/watch?feature=you ... 9qoJm3nsvA
buguy
Post by buguy »
Sounds tough!
She loading up a little at idle? Do you know your AFR?
advinnie
Post by advinnie »
She was loading up but I’ve sorted that out now. I had a bad needle valve and it was not shutting of the fuel that well and was slowly flooding the engine when at idle so changed it and all’s good. Yes I have a lm-2 hand held reader but it’s just reading 100% rich at idle (8.5:1)
buguy
Post by buguy »
Well I love the way a draw through sounds so I'm biased. I love that crackle! I have been working on that with my 4 barrel. I'm not sure if it's better to have it a bit leaner at idle to save from carbon monoxide poisoning and in case of a traffic jam and have to fatten up quicker as it builds boost, or to just run it around 12.5 or so and less risk of a lean spike. I guess it's all about experimentation.
advinnie
Post by advinnie »
I’m planning on running it slightly rich to play it safe for the moment. I’m seeing 14.1:1 on a cruise and at WOT no boost I’m getting a reading of 13.0:1 and WOT @ 8 psi I was seeing 12.4:1 but as soon as she starts to idle I get a reading of 8:1
buguy
Post by buguy »
Sounds like you have it running pretty well besides the idle. I wish I could help but I have never touched one of those carbs.
WickedWagens
Post by WickedWagens »
That exhaust sounds great!
1968 Karmann Ghia land speed
G/CFALT 106.643 MPH G/CGALT 113.131 MPH
G/CBGALT 169.462 MPH G/CBFALT 146.715 MPH
G/CBGC 158.242 MPH H/CBGC 94.334 MPH
H/CPRO 93.383 MPH H/CBFALT 101.282 MPH
H/CBGALT 120.591 MPH
Top Speed 174.2 MPH
advinnie
Post by advinnie »
Cheers mate.
I do have one small problem I need to sort out and that’s it now. The carb icing has now been sort, I sorted that but getting a 2” diameter hose and rammed it up underneath the cylinders to catch all that lovely hot air and routed the other up underneath the carb manifold and it’s worked a treat. Anyway the last issue I have to over come is if I accelerate normally all is good the engine picks up speed and nicely comes onto boost but if I floor it in any gear she will stumble and popping can be heard from the exhaust.
buguy
Post by buguy »
I seem to get that with mine if I have a vacuum leak somewhere. Have you check that out yet?
advinnie
Post by advinnie »
I will go recheck now for a vacuum leak
