My draw through turbo
Moderator: seabeebuggy
rubenski
Re: My draw through turbo
Post by rubenski » Sat Jun 02, 2018 9:47 am
I want one of those too.
But have not yet found them for sale in my country.
Dont want to pay high shipping costs from the usa...
Im in belgium btw.
advinnie
Post by advinnie » Sat Jun 02, 2018 10:48 am
You could try coolair here in the UK post should not be that high that's if they post to you?
This is all the mounts they do
https://www.coolairvw.co.uk/Category/0/ ... mance.html
Clonebug
Post by Clonebug » Sat Jun 02, 2018 3:44 pm
Here is what you want. It's nice if you find some longer studs and replace the ones you use to mount the support.
You can just back them out a bit but better to use longer ones.
https://www.coolairvw.co.uk/Item/Shop_b ... pport.html
rubenski
Post by rubenski » Sat Jun 02, 2018 4:27 pm
Yeah, found it.
I will create an account and see how much shipping will be.
Thanks!
Plus they have the billet dash knobs i was looking for.
petew
Post by petew » Mon Jun 04, 2018 7:03 pm
Yeah, I should pull my finger out and fit mine. I'm pretty over the noise and vibration of the trans straps. My trans already has all the lengthened studs ready to go. Procrastination. :(
advinnie
Post by advinnie » Tue Jun 05, 2018 4:32 am
Yes pull your finger out and get it fitted 😁
Well I had an electrical fire yesterday 😠 lucky the bug didn't go up in flames. The dimmer switch earth wire melted and wiped out the hole loom that comes from the indicator unit.
petew
Post by petew » Tue Jun 05, 2018 4:52 am
:( Sorry man. That sucks.
advinnie
Post by advinnie » Tue Jun 05, 2018 5:11 am
It bloody does I would post some photos but I just can't figure out how to down size them on this Huawei phone 😡
advinnie
Post by advinnie » Sat Jun 16, 2018 3:37 pm
Hi all the turbo bug ( BKUE THUNDER) is still running great although I had a close call the other day for some reason my wastegate failed to maintain my boost pressure at the set 8psi and ended up hitting 16 3 psi 🤪 don't know what went wrong or way still looking into it.
Anyway I'm looking to increase the engine size but wanted to know what size pistons and barrels to go with,
Should I play it safe with the thicker walled 90mm's or go with the thinker walled 94mm ones?
Also I'm wanting to increase the rev range of this new engine from 5500rpm (witch is my 1600 engines max) to 7000 rpm but to gain this increase should I stay with the sorter stroke 69mm crank or will a larger crank like a 78 mm or 82mm still be able to turn at these higher rpm's ?
Post by Chip Birks » Sat Jun 16, 2018 6:59 pm
Go thick wall 92s. I limit my 2276 to 7500, it gets there no problem.
advinnie
Post by advinnie » Sun Jun 17, 2018 3:54 am
Cheers mate 👍
advinnie
Post by advinnie » Thu Jun 21, 2018 2:08 am
Hi all I'm back 😁
Has any one on here ever played around with a rear disc brake conversion on their bug and if so is it worth it?
Also I'm after more rpm's. When I first built this turbo engine I was more than happy to keep the rpm's down below 5000 rpm but now I've noticed that I'm now pushing this limit. I very often hit 6000rpm and the other night I was silly and hit 6532 rpm when I was going over my data log. So a CW crank is needed but is it worth stepping up the crank size to a 74mm to give me a 1699cc or just stick to a 69mm CW crank?
What's your opinions?
madmike
Post by madmike » Thu Jun 21, 2018 6:34 am
Hey Adam, what cam u running? Hell ya go big or 'stay on the porch'
78mm is my next build :lol: I set my shift lite @ 6000 but me being old sometime I shift at 7.5-8k :lol: sloooow reaction :lol: :lol: :lol:
advinnie
Post by advinnie » Thu Jun 21, 2018 7:27 am
Hi mate I'm only running a engle 100 cam and I must say it's working great.
I am really in two minds if I do or do not increase the engine cc's. My old 2276 motor was bloody amazing with great low end torque and often hit 7000rpm but she always ran hot on a long run and the mpg was not great and am a little afraid that if I built an engine of this size again and through a turbo on it it would all go wrong. Anyway this little 1600 is just as fast when on boost as the 2276 and I'm getting between 18-22 mpg out if it but I just want more rpm's. Now , and I know I'm going to get told off for doing this , I decided to see what the upper rpm limit was on this 1600 ( yes I know you should not go passed 5500rpm) so with a friend in the passer seat we set off and all he had to do was shout 7 if and when I hit 7000 rpm. So in first gear I flood it and in just seconds I hear "7" second gear and a second later 7 into third hit 8psi boost instantly then 7 into fourth needle goes way pass the 90 mph mark on the Speedo and I lost my bottle and called it a day. Had a look on the laptop and highest recorded rpm was 7281rpm. So long story short the little 1600 can easily get to 7K so when I change the crank do I even bother going for the 74mm one to give me a 1699cc engine ?
madmike
Post by madmike » Thu Jun 21, 2018 7:56 am
No put down from me I luv it 8) :lol: But if you go 74 mm you will have more torque then a 69mm :wink: plus the fact u won't need to go that high of RPM's to a do what that 1600 just did,, my 2276 runs hot when I boost alot like this past wknd I was burning out/ hole shot every few meters within minutes of each other ,, 4 oil coolers help I just backoff & cruise, temps come back down to 190-210*f ish. :shock: :lol: but normal driving on a trip= normal temps
