1641 Turbo EFI Manx. 250Hp/337Nm Turbotub
- rubenski
Re: 1641 Turbo EFI Manx. Stage 2: Mockup!
Next issue,
My injector holding bracket seems to be too tall.
Guess i have to make one?
- petew
I'd just smash it all together and pressure test it. If it leaks you can build a shorter clamp.
- rubenski
It will leak, you can move the injector around with this clamp. You can feel the o rings are not set.
A couple of weeks ago we had problems with O-rings ourselves; they are very delicate especially if used or compressed wrong.
http://www.applerubber.com/hot-topics-f ... lications/
This has to deal with O-rings used with sensors.
- petew
- rubenski
- petew
I'll go and have a quick squiz again, but I think it's fine and no, it hasn't leaked. The only bits that leaked were the screw in fittings that I didn't do up tight enough. That's why I say, put it together and pressure test it first without starting the motor. You'll know soon enough if there's and issue.
- petew
Have you got the clips on? The clips that hold the injector to the rail.
- rubenski
I took it off to see if they would drop deeper in the manifold
- Chip Birks
Can you flip that bracket over?
- rubenski
How do you mean? Flipping it wont make it shorter?Chip Birks wrote:Can you flip that bracket over?
- Chip Birks
Sorry, the pictures made me think i was seeing something that i wasn't.
- rubenski
Yeah, my phone's camera is kinda busted....
- panel
Re: 1641 Turbo EFI Manx. Gathering parts!
Is this still the CB part you're working with? Do you still think it's the injector to blame ?
- rubenski
Its a custom project with parts from here and there.
Hahahaha
I know what u mean
Hahahaha
I know what u mean
