1641 Turbo EFI Manx. Stage 2: Mockup!
Moderator: seabeebuggy
rubenski
Re: 1641 Turbo EFI Manx. Gathering parts!
Post by rubenski » Wed May 02, 2018 9:28 pm
Hey pete, no i dont play, i found that red box on the side of the road, left behind. With 2 verry big speakers in it. No amp. I got it hooked to my radio, it plays as loud as i can bear...
And yes, i think i will have the ecu control them. Probably by IAT. Or maybe 1 all the time and the 2nd when it gets on boooooooost!
rubenski
Post by rubenski » Thu May 03, 2018 9:37 am
Hi.
I got my turbo flange welded!
The little tab on there is to put a bolt trough to keep the stock wastegate valve closed.
Next up is ordering my stuff from cb performance.
Wastegate, bov, ecu, loom, crank trigger, fuell rails and misc parts!
buguy
Post by buguy » Thu May 03, 2018 12:08 pm
Looks awesome! Your getting close!
Post by Chip Birks » Thu May 03, 2018 12:22 pm
How are you holding your wastegate shut?
rubenski
Post by rubenski » Thu May 03, 2018 12:44 pm
A nut between the flange and wastegate-arm,
A bolt trough the little hole,
Some red locktite et voila!
Post by Chip Birks » Thu May 03, 2018 1:56 pm
Nice and simple. I had to weld one up recently, was surprisingly easy to do.
woodsbuggy1
Post by woodsbuggy1 » Thu May 03, 2018 7:30 pm
Looking Great! I hate to admit that I ran a cheap ($50) Emusa brand Chinese wastegate for 3 years with zero problems. I have a difficult time recommending Chinese parts but the cheap one worked very well for me. Bosch BOV is also a great part for the $20 that they cost on ebay. I buy as few parts as I can from CB, their customer service has been horrible and almost every part that I have bought from them required modifications.
Good Luck
Kenric
rubenski
Post by rubenski » Fri May 04, 2018 1:37 am
Must me user specific. Never had issues with cb...
When i had to figure out their blackbox they helped me verry good!
rubenski
Post by rubenski » Fri May 11, 2018 3:55 pm
Hi all!
Gaskets for the turbo exhaust arrived. 5layer stainless.
Played monopoly today,
Walked by "cbperformance-street"
I chose the most expensive hotel
Oh boy, the efi game is on!
rubenski
Post by rubenski » Sun May 13, 2018 6:20 am
Cut of the intake manifold end pieces, and some new 50mm tubing.
So everything is matched in intake diameter.
Will need a serious flow-job after welding!
buguy
Post by buguy » Sun May 13, 2018 8:49 am
Ooooh! I'm jealous! Your moving forward!
rubenski
Post by rubenski » Mon May 14, 2018 3:06 am
Not really, just taking on small jobs that dont have to wait till winter.
Really not much more to do without removing parts that make driving the buggy impossible
rubenski
Post by rubenski » Wed May 16, 2018 3:49 pm
Quick question,
Would the cooling of the heads be much affected by cuting of the horisontal pieces what have the cylinder stamped on them?
This would ̀ clean up the look of the engine tin.
Stupid? Maybe?
You ever tried it?
Post by Ol'fogasaurus » Wed May 16, 2018 4:31 pm
Quick question,
Seen it done on rails and a couple of buggies.
Personally, I would limit cutting back the tin because if you leave a flange it would become a stiffening flange that keeps the rest of the tin from flexing and potentially causing stress fracture. I would end up cutting material off about a safe 3/8th inch outboard from the outside join of the bend (aka OML/outside mold line) to the straight flange... just to be safe.
I haven't got around to doing it yet myself. It also may give some additional access to the engine and help with air flow.
rubenski
Post by rubenski » Wed May 16, 2018 11:32 pm
Ok. Thx!
