Turbo this baja discusion
Re: Turbo this baja discusion
cool thought maybe they were to prevent warping with the heat cycling and such.
Thinking about air/water inter coolers Turbo pressure side is 2.25" My Idf throttle body covers are 2.5". I see you can get them in 2.25 or 2.5 from From http://www.frozenboost.com/air_water-ic/ My thought was to keep it 2.25" from turbo > inter cooler > 2.25 > T 2.5 split pipe > throttle bodies. or 2.25" turbo > 2.5" > inter cooler > T > throttle bodies next where do you find the tipping point where your inter cooler is to big ? I was planning on finding pressure size tube to use then making cardboard inter cooler dummy to see/plan placement Kinda need to learn some good practice turbo plumbing / inter cooler rules
Off to work
Later Guys
Terry
Off to work
Later Guys
Terry
Terry Lytle
Canada
2180
8.5-1 comp
JE forged pistons
Porsche piston squirters
30mm triple "O"ring pump
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
SL-1 Turbo prepped heads
Canada
2180
8.5-1 comp
JE forged pistons
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
Cleaned the pix up a bit so I could see detail better.
- Chip Birks
I have one of the frozen boost intercoolers, rated at 600hp, it has 3 inch in and out that i just use adaptor silicone to get the diameter i actually use. It keeps my temps under control nicely, I'm not in 600hp territory. Probably more like 350-400 when set on kill. You will find the exact same intercoolers on ebay, for significantly less $$$ shipped. I need a new one and will be going the ebay route this time for sure.terryly wrote: ↑Mon Jan 08, 2018 6:33 am cool thought maybe they were to prevent warping with the heat cycling and such.
Off to work
Later Guys
Terry
Thanks Chip Birks Did some poking around and reading last night. Can't really find any reason to go a little oversize. Then then the more I thought about it The intercooler itself is a size change in the plumbing system I was just getting hung up on changing sizes up and down as little as possible alsa keeping bends and direction changes to a minimum with a short run. I am leaning to using this style in 2.5"
This should allow me to place it above the engine air shroud keeping it out of harms way. Going from 2.25" out of the turbo >reducer> 2,5" Center port of Intercooler exiting on offset port >to a 90* coupler > to a off set T and finally out the T to each throttle body pressure hat 90* coupler Seems like it might work.
Going to make a dummy card board intercooler and see if it is possible
Until next time take care
Terry
Terry
Terry Lytle
Canada
2180
8.5-1 comp
JE forged pistons
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
Canada
2180
8.5-1 comp
JE forged pistons
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
Make sure you get the reducers before you buy the intercooler!!!!!
The TD04L turbo has a 1 7/8ths inch compressor outlet and reducing couplers are very limited in that size.
I found one for 1 7/8ths - 2 inch but I'm not sure what other sizes are available.....
Check first.
Check first.
- Chip Birks
CXRacing on ebay has 1.875 to 2.5 90° reducers available. I'm sure they have more. Pricing is decent.
By Golly they do.....Carry on......Chip Birks wrote: ↑Tue Jan 09, 2018 12:09 pm CXRacing on ebay has 1.875 to 2.5 90° reducers available. I'm sure they have more. Pricing is decent.
ShopTalkForums and you guys are great Good call Clonebug Don't know how I got 2.25" turbo outlet in my head. Just happy that I now have out of my rear end Was a busy weekend pulling the Baja out of snow, thawing it out,IMAGINING WHERE TURBO GOES,removing motor,making flanges,pushing back out and enjoying some beer.
Good find Chip Birks Was hoping to come strait out of turbo and increase there. I poked around a little last night and also found the 90* like you linked to but could not find a strait 1.875" to 2.5" .Might have to put a 90 at turbo and re-visit pressure side lay out.
Clonebug do you have an application or link for the 1.875" to 2" reducing coupler ?
How about a 1.875 strait coupler then use an exhaust pipe Expander for slip joints to make up the size up and use common reducer to get the rest of the diameter one is after. Sound like it will work ? or is my head missing again
Back down to sub zero temps up here -27*C low tonight -22*C daytime high Work will be more challenging for next couple of days I was down with a dislocated shoulder during the last cold snap at Christmas and pretty much just hunkered down to hibernate and heal
Well have a real good day folks till next time
Terry
Terry
Terry Lytle
Canada
2180
8.5-1 comp
JE forged pistons
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
Canada
2180
8.5-1 comp
JE forged pistons
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
I go to frozenboost.com or siliconeintakes.com for my connectors.
Hello just wanted to post an update of where I'm at with this. Picked up some new hole saws Plotted the holes on the flanges that were previously cut and drilled them out Tacked in a length of 2" exhaust tube and bolted the turbo up. I also made a card board intercooler for plannig. here is how it looked
Wanted to get the intercooler a little more centered and did not like what I was left with for air filter placement and oil fill access so we turned it around and re clocked it Well that seemed to open up some possibilities. so I rolled some print paper into a tube [it was only 2" not 2.5" but was able to let me imagine it better.] and this is what we came up with using this intercooler
I am really digging this lay out !!!I will probably raise the turbo up a couple inches and tilt the intercooler to get a strait shot at the inter cooler. It will get a1.875" -2" coupler then a 2"-2.5" reducing coupler to intercooler. then a 90* coupler out to a T. Then a Couple 90* elbows to the throttle bodies. This layout puts the air filter pretty close to where it was which I like for side mirror and rear window visibility. It also really frees up the oil fill canister that has always been a bit of a pain to get to. And this makes the exhaust pipe and muffler routing sensible and easy to build.
The plan is to build as much of the pressure plumbing out of silicone tubing using joiners at the elbows and splices as needed.
These for out of turbo 1.875" - 2" and 2" - 2.5"
And these to splice
Some 90*
Some lengths of silicone tube
They even have 4" - 2.5" for turbo inlet to air filter still have to get from 2.5" to 1.9" turbo size
Pretty simple and hopefully durable and reliable. Cant seem to locate aT for out of the intercooler to throttle bodies. Spent more time trying to search one online than it would take to make one I would think it would be wise to extend the T to past the turbo up pipe as I don't know if silicone would be up to the heat where they cross. Better safe than sorry I guess.
Here is a shot of where the air filter was worked real good. Thinking maybe i can put the radiater for air water intercooler up on the rack. have to find a short wide cooler/ radiator Should be protected up there and in the air. Could also put puller fans there for high load low speed situations.
You can also get an idea of how the turbo will be and see how it might be on the car. I think it will look right at home there Should be cool
Also made flanges for #1 and #3
Well that's how my plan is for now
Terry
And these to splice
Some 90*
Terry
Terry Lytle
Canada
2180
8.5-1 comp
JE forged pistons
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
Canada
2180
8.5-1 comp
JE forged pistons
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
ALRIGHT Just sold my old Low Bugget Kads and svda distributor for $450 to some guy in the local club going to get rid of the 40 & 44 IDFs too Hell I'm getting rid of the CB Magnaspark Digital distributor an old exaust,some buggy seats steering parts All in my lust for boost
Terry Lytle
Canada
2180
8.5-1 comp
JE forged pistons
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
Canada
2180
8.5-1 comp
JE forged pistons
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
- buguy
No turning back now!
- Chip Birks
- buguy
Oh! Well then carry on!
WAHOO Guy just came over and took my Kads another guy took my suspension, seats got a guy figuring out how to get a 2017 stroker internals to the next province over and another guy nibbling at my IDF carbs and digital distributor package
Should give me a good "leg up" for a not out of the pocket TURBO SLUSH FUND
That and the kids gave me enough TURBO SLUSH FUNDstocking stuffers for Christmas to pick up a turbo,gaskets,flange material,hole saws and exhaust pipe
Busted myself up in the form of a dislocated shoulder Dec 15 Not working for a couple of weeks was threatening to choke off the funny money fund
so this an unexpected surprise. So glad to be back at work!!!
This is coming along better and sooner than I would have thought
I will keep you posted as this continues . Thanks all
Terry
Terry
Terry Lytle
Canada
2180
8.5-1 comp
JE forged pistons
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
Canada
2180
8.5-1 comp
JE forged pistons
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
