Air water intercooler water core
turboedbug
Post by turboedbug »
Where are ya type 1 guys placing your water core?
Sent from my SM-J727T using Tapatalk
Turbo!
turboedbug
Re: Air water intercooler water core
turboedbug wrote:Where are ya type 1 guys placing your water core?
Bump.
Yup still curious where ya placing the heat exchanger
Turbo!
risk
Post by risk »
My intercooler is in the engine bay. The radiator, fan and pump are under the parcel tray hanging next to the transaxle. Tank is behind the back seat in the parcel tray area.
turboedbug
risk wrote:My intercooler is in the engine bay. The radiator, fan and pump are under the parcel tray hanging next to the transaxle. Tank is behind the back seat in the parcel tray area.
Hmm i might need to give that a shot and see if my exchanger could fit next to the transaxle.
I have been tempted to run it up front to take advantage of all that free air. But i dont want it to be seen
Turbo!
Post by Chip Birks »
My intercooler is sitting above the parcel tray. Tank is under the back seat opposite the battery. Heat exchanger is next to the torsion tube on drivers side. Pump is inside the tank.
petew
Post by petew »
Core in the engine bay...
Pump on the rear torsion housing...
Alloy pipe under the car...
Radiator in front of the beam at the front of the car...
I had a different radiator and fan next to the trans, but I couldn't get it to work properly. Constant issues with heat soak and air supply. The new radiator works a lot better, but it does hang a little low. I could have cut into the spare wheel well, but I haven't. Looks dead stock until you get the car up off the ground. On average, charge air is 15-20degC above ambient. So in a hot place like Aust, I'm pretty happy with it.
risk
Post by risk »
I like that rock guard!
petew
Post by petew »
Let's just say I'm paranoid about the radiator getting hit. ;)
bug66
Post by bug66 »
My old system:
New setup:
Intercooler size:
2165cc on a Borg Warner S257 SXE, DTA S60 on E85.
Boost was created only to make people smile, and make power! 8)
10.626 @ 132mph SCC2016
10.407 @ 134mph SCC2017
10.221 @ 135mph SCC2018
Dan Dryden
Post by Dan Dryden »
bug66 wrote: Wed Feb 28, 2018 2:02 am My old system: 12.jpg
New setup: 11.jpg
Intercooler size: 13.jpg
You’re gonna be getting icicles hanging off those boost pipes! 😂
mactaylor
Post by mactaylor »
Very cool! Pun intended! Bit heavy though?
bug66
Post by bug66 »
I had 81C / 177F intake temp with the last setup at the quarter mile mark, so every degree I can get it down gives a good amount of power gain.
Weight is not that relevant. A lot of power and torque on tap with the last setup :)
turboedbug
Lots of good ideas here, i currently run a radiator up front for my suby motor so room is limited in front of the beam.
Been tossing the idea around about putting a core next to the trans.
Guess we will see what happens once i put the body back on after i fix these rust problems
Turbo!
