Weber 40 dcoe idle setting
Moderator: seabeebuggy
advinnie
Post by advinnie » Wed Jan 10, 2018 8:35 am
Hi all just a quick one, I’m using a Weber 40 dcoe in a draw through turbo set up on my bug, now to get it to idle at 900-1100rpm I have to wind in the idle speed screw a long way and the butterflies are uncovering the progression ports. Now to bring the butterflies back into the correct position could I just increase the idle timing a little more?
Clonebug
Re: Weber 40 dcoe idle setting
Post by Clonebug » Wed Jan 10, 2018 9:01 am
Yes you can but you will have to somehow limit your max timing since you don't have any control on the distributor........unless you have a black box or something....
advinnie
Post by advinnie » Wed Jan 10, 2018 11:25 am
I have full control of my timing so that is not a problem.
buguy
Post by buguy » Wed Jan 10, 2018 7:55 pm
You could always drill holes in the butterflys
rs58rag
Post by rs58rag » Fri Feb 02, 2018 7:09 pm
NOOOO!!!
