Turbo construction questions
Moderator: seabeebuggy
Post by theKbStockpiler » Sat Jan 13, 2018 10:44 am
Hi, Are turbines one piece with the shaft? Is the compressor a spine fit?
Thanks for your expertise!
Super beetle with attitude
Re: Turbo construction questions
Post by petew » Fri Jan 19, 2018 6:15 am
Turbine wheels are 1 piece with the shaft (I think). Compressor wheels are generally not splined. If you pull it off, you should mark the nut and shaft beforehand.
