Cracking and banging of of exhaust
Moderator: seabeebuggy
advinnie
Re: Cracking and banging of of exhaust
Post by advinnie » Fri Jan 26, 2018 4:33 pm
You running a dyno or alternator don’t know if that will make any difference?
I’m running a alternator.
From what I’ve read the coil should see battery voltage at all times. I will recheck mine tomorrow to see if the coil is seeing exact battery voltage.
advinnie
Post by advinnie » Fri Jan 26, 2018 4:39 pm
Just a thought there’s not a voltage controller in the stock Vw wiring that only allows the coil to see 12 volts?
Cause now I’ve wired the coil to battery I have a funny feeling that the coil will be receiving 14.7 volts at some point cause that’s what the battery sees from the alternator at a certain rpm if that makes sense?
buguy
Post by buguy » Fri Jan 26, 2018 6:57 pm
Yeah I just checked again and its less than 9v at idle. I guess thinking about it now I should have revved it up to see how much it changed. I believe this is a 1975 engine so it should be an alternator. I don't really know how to tell the difference to be honest.
petew
Post by petew » Fri Jan 26, 2018 7:24 pm
Alternator
Generator
Alternator is better, but a generator will provide charge at any revs. Alternators have to have certain speed to start making charge.
Edit: in this pic you've got an alternator...
https://www.thesamba.com/vw/gallery/pix/1664965.jpg
buguy
Post by buguy » Fri Jan 26, 2018 10:00 pm
Thanks!
advinnie
Post by advinnie » Sat Jan 27, 2018 1:34 am
Who’s engine is that in the link?
Was wondering where that got that exhaust manifold from and what size it is
petew
Post by petew » Sat Jan 27, 2018 5:14 am
Buguy's
buguy
Post by buguy » Sat Jan 27, 2018 8:32 am
That is just a 1 3/8" old old old header that I cut up and turned, welded, and hit with a hammer 'til it worked.
advinnie
Post by advinnie » Sat Jan 27, 2018 8:41 am
I see I need a new one soon mine is not in the best of shapes. I’m guessing you can’t make me a new one up and stick it in the post I’m only in the UK 🇬🇧 so justvdown the road of you 😂😂😂😂😂😂😂😂😂
buguy
Post by buguy » Sat Jan 27, 2018 9:21 am
In a couple weeks you can have that one! I'll just bring it to you! I have a boat! It's not inn good shape either. I found several pin holes and its so thin now that you can barely weld it without blowing right through.
advinnie
Post by advinnie » Sat Jan 27, 2018 9:35 am
Nice one cheers mate👍🏻
I have a small row boat so I will start out now and meet you half way 😂
advinnie
Post by advinnie » Sat Jan 27, 2018 12:11 pm
Well I will not be fitting and running my new boost controller this weekend 😡 it turned up today and it’s broken the company are willing to give a full refund there’s no problem there just bloody pissed of it turned up broken 😡
buguy
Post by buguy » Sat Jan 27, 2018 1:18 pm
Awwww. That's the worst! So just pull the waste gate hose off and watch your boost gauge!
advinnie
Post by advinnie » Sat Jan 27, 2018 2:36 pm
That’s why one to gain max boost 😁
All my little 1600 can do with this turbo is produce 14.5psi @ 4900rpm so why just the wastegate 😂
buguy
Post by buguy » Sat Jan 27, 2018 2:54 pm
I'm in the same boat. I'm not sure I can even get that much boost yet.
