EFI parts gathering
Moderator: seabeebuggy
Clonebug
Re: EFI parts gathering
Post by Clonebug » Sun Feb 04, 2018 6:44 pm
buguy wrote:
Sun Feb 04, 2018 5:38 pm
Well I only asked because I see new Holley's for around $60.
You could probably run the Holley if it is boost referenced and is adjustable. You need to run 43.5 lbs. fuel pressure and also reference to boost so it goes up when boost goes up.
The stock German one is at 43.5 lbs by default and has a connection for a hose to the intake runner.
Post by Chip Birks » Sun Feb 04, 2018 7:18 pm
Biggest difference will be the the ability to adjust pressure, as well as having the ability to run any hose you want.
Clonebug
Post by Clonebug » Sun Feb 04, 2018 8:32 pm
That's one of the best parts of MS EFI.....you can do it whichever way you want. There are many different ways to accomplish the same thing.
You get to pick which one works best for you.
You are the engineer and the mechanic...... 8) :wink:
buguy
Post by buguy » Sun Feb 04, 2018 9:44 pm
Why would the regulator need to be boost referenced? Boost shouldn't affect injectors?
rubenski
Post by rubenski » Sun Feb 04, 2018 9:56 pm
My FI regulator is boost ref also. 1:1
Post by Chip Birks » Sun Feb 04, 2018 10:25 pm
Good read here covers carb, then efi.
http://fuelab.com/11-boost-reference-fu ... egulators/
buguy
Post by buguy » Sun Feb 04, 2018 11:45 pm
Interesting. I wouldn't have thought boost pressure would have affected injectors.
Clonebug
Post by Clonebug » Mon Feb 05, 2018 7:35 am
At 43.5 lbs fuel pressure and then pushing back at 22 lbs.....that leaves only 21.5 lbs of fuel pressure left. What do you think that would do for tuning it.
You need a steady pressure. Boost referencing keeps it at a steady 43.5 lbs at all times.
buguy
Post by buguy » Mon Feb 05, 2018 6:25 pm
Well then I better boost reference it!
buguy
Post by buguy » Tue Feb 06, 2018 10:52 am
So I'm thinking ahead to wiring. I've heard a couple guys mention the extra time it takes to remove the engine. Suppose it would be worth while to put a weather pack connector at the firewall so you could just unplug the entire engine harness and pull it with the engine?
Post by Chip Birks » Tue Feb 06, 2018 11:29 am
I did that at one point, then added more wires to the system. In the end I removed that plug. I think I'd need 2 or 3 to do the job in my engine compartment now. I don't like the bulk of the connector. I now have 6 or 7 smaller ones that I unplug with 8 to 10 wires each. That way there is no big harness hanging out in the engine compartment to pinch when stabbing the motor in next time. It all comes out with the engine. I'm going to reconfigure again though. Still trying to find the best method.
buguy
Post by buguy » Tue Feb 06, 2018 12:11 pm
I guess maybe I should lay it out on paper and see how many wires I will have and how many I might have if I do any upgrades.
rubenski
Post by rubenski » Tue Feb 06, 2018 1:03 pm
What do you allready have?
buguy
Post by buguy » Tue Feb 06, 2018 1:52 pm
Nothing yet
buguy
Post by buguy » Tue Feb 06, 2018 10:38 pm
Wait I forgot. I have a fuel pressure regulator coming. Thanks for the find Clone.
