Its true, not many. The Fitech is what threw me off the scent. You had been preaching Halteh pretty heavily on thesamba, with emphasis on the flex fuel capability. Kinda surprised to see you switch gears so fast. Though Rodney does do good work and offers some pretty sweet products. Glad to see you getting things nailed down a bit. Sounds like you'll be commited to e85 unless you plan to run Super Squish pistons. 9.5 will make for good fun off boost. Mine is set at 9.1 currently, and has seen over 25psi on e85 with plenty of boost to go, I aggressively attack intake temp increases though. Water to air intercooler, water/meth injection.
MAX boost psi...how much?
- Chip Birks
Re: MAX boost psi...how much?
The truth is this Chip, I have been researching efi systems now for almost a year and I truly believed in the haltech elite series. ..when I called Paradise Motorsports in CA to get a dyno quote, I spoke shortly with Kris Lauffer and he informed me that he stopped using the Haltech due to the overseas delay in customer service. ..he did say that their systems were decent though...the Fitech system with intake is a complete convenience bolt on with limited capabilities and has a good price point but is limited to 25 psi. ..I think I would rather be a lot more happier with a efi system that is not limited, although it will cost me gobs of money
I see You did contact Mike @ Turbo's Direct?
YES I did, thanks madmike. ..Mike was incredible to talk with and a super nice guy...he gave me the info I needed and recommend a turbo size. ..when it came down to journal or bearing turbo he left it up to me to decide and explained the difference clearly. ..I enjoyed our conversation...I will be getting my turbo parts from Mike when I get to that stage of my build...thanks for the hook up!
