Alternator belt
Amurray
Alternator belt
Post by Amurray »
Ok need a little help. What would make a brand new alternator belt flip? This one is now no good. I lost one a week ago testing my car out. Had to shut her down due to not having a spare. Heck a few things happen that day......1. lost boost as the intake pipe blew off(note to self always bring tools :( 2. Lost on of the nuts for the engine bolt 3. lost my fan belt. All in all it was a good day :twisted:
risk
Re: Alternator belt
Post by risk »
Have you checked the alignment of the pulleys? Use a long metal ruler or straight piece of steel to check.
They make a shim kit to solve alignment issues.
High rpm will throw a belt easier if the belt is a little loose or things aren't perfectly aligned.
madmike
Re: Alternator belt
Post by madmike »
Mine was doing this and It was caused by the alt. shim,, seems it didn't need one :wink: :lol:
Amurray
Re: Alternator belt
Post by Amurray »
Thanks, I'll try the "no shims" and see how that works. More testing this weekend. Also I think I'm going to switch to the "REV6" dual clutch before I go back to the dyno.
