Wastegate and Blow off setup??
I have blow thru dual tb efi setup and I'm trying to figure out how the vacuum lines go for the wastegate and blow off valve. Right this sec my vacuum setup is TB to a tee to another tee that goes to FPR then to EMS. I have vacuum ports on my intake manifolds too. Just trying to figure out vacuum line setup for the wastegate and blow off valve.
- slowsixtyduece
Re: Wastegate and Blow off setup??
Heres a simple drawing I did to illustrate how my vacuum lines for the WG & blow off valve were to be routed. I decided to tap into the cool side of my turbo compressor and run my WG off of there, but the WG can be tapped into just about any part of the intake track post turbo and pre-throttle plate. BOV must come after vacuum to actuate the BOV itself. Hope this helps. When theres a million other things to do to get a motor up and running, its easy to forgot how things should go (at least for me)
Just so theres no confusion, here are what the abbreviations mean (pretty self explanatory):
FPR=Fuel Pressure Regulator
WG=Wastegate
BOV=Blow off Valve
MAP=Manifold Air Pressure Sensor
WG=Wastegate
BOV=Blow off Valve
- woodsbuggy1
I having been getting all of my vacuum/boost signals from below the throttle plate. Has worked well for me.
Kenric
Kenric
- slowsixtyduece
Me too. I dont think you can get accurate signals if you are mounting before the throttle plate. At least with my setup the MAP needs to see both boost and vacuum and the best place for it is right after the TB plate in the intake tract, before the intake ports on the head(s).I having been getting all of my vacuum/boost signals from below the throttle plate. Has worked well for me.
Kenric
Appreciate all the info. I'm using Megasquirt MS3 with built in expansion so it has MAP built into the box and that's where I found the vacuum setup diagram for FPR, EMS, and TB. As you can probably see I'm new to all this Turbo EFI stuff. Definitely a lot to learn and read about.
Your Map Sensor and BOV needs to see Vac/Boost. I have mine hooked up on the intake just below the TB. I put a tee in the line to go to both the MAP and BOV. It also goes to the stock German FPR to give it a vac/boost signal.
Here you can see the Vac/boost nipple in the back of the intake.
My turbo compressor outlet is hooked to the Electronic Boost Controller and the two Hobbes Switches. The EBC then sends the regulated boost signal back the the wastegate to control how much boost I set in the ECU.
Here you can kind of see the hoses running to the EBC and the Hobbes and also coming from the intake connector and teeing off to go to the ECU.
It does get a little busy there.
Here is the line to the BOV.
