Finally starting on a blow through Kadron motor
Moderator: seabeebuggy
Lo Cash John
Re: Finally starting on a blow through Kadron motor
Post by Lo Cash John » Fri Jun 15, 2018 3:39 pm
I think for myself I might build another Kadron turbo motor but I might make mine "stealth". Go with a K3 turbo tucked under the apron, then run pressure pipe below/past motor to bellhousing area. I'd then pipe my kads together with a pipe on the rear side of the fan shroud. I could disguise the pressure hats with old kadron air cleaners. If someone looked real close they'd figure it out, but at a glance it'd look like any other dual kad motor.
buguy
Post by buguy » Fri Jun 15, 2018 4:21 pm
Would you run the up pipe from the turbo up behind the shroud too?
Lo Cash John
Post by Lo Cash John » Fri Jun 15, 2018 4:40 pm
The turbo would be tucked behind the rear apron, like a CB performance Hide-a-way header does. I'd figure a way to build an air filter box under the rear fender. The turbo outlet (pressurized fresh air) piping would be run so it's not visible with the deck lid open. It would come up behind the fan shroud and feed a crossover pipe that's also back there. This might require moving the firewall forward a few inches. No big deal though.
Booky
Post by Booky » Sat Jun 16, 2018 5:43 pm
Keep us posted on the progress I have been wanting to do the same with a 1600 kadrons .Im looking at doing it over the winter on a Sandrail that is built for the road.
Buggsy
Post by Buggsy » Sat Jun 16, 2018 8:38 pm
Clonebug wrote:
Thu Jun 14, 2018 9:14 pm
You might want to extend the float bowl vents into those carb tops.
Nope, you don't want to do that. Tried it in 2001. You don't have to do anything to the Kads but rejet, and ensure the throttle shafts don't leak. The limiting factor will be how much the float can handle before it crushes. I know they are good to at least 12 psi.
Clonebug
Post by Clonebug » Sat Jun 16, 2018 11:00 pm
Every carb is different.....it's an option if he needs more fuel on boost. I myself don't want to see another carb ever but that's just me..... :wink:
I wasn't too impressed with Kadrons N/A...I'm curious to see how they perform under boost.
Although......I had a single port 1500 that ran really, really sweet on dual Kadrons.
I still have those carbs and intakes sitting somewhere on the shelf.
Udo Airbus
Post by Udo Airbus » Wed Jun 27, 2018 1:18 am
Any update John?
VW T1 1964 - Mouse Grey - Pearl White OG paint
Bagged, Porsche steeringrack/brakes..IRS, AMR Supercharged 1600 (sold) building a 1971cc EFI turbo/supercharged engine
Lo Cash John
Post by Lo Cash John » Wed Jun 27, 2018 10:20 pm
No updates yet. I'm out of town for work and won't be back until July 3rd.
Next steps are:
Complete the 3" exhaust
Fab up a breather box
Sort out the oil, fuel and breather plumbing
Modify stock fuel pump for boost
John S.
Post by John S. » Tue Jul 03, 2018 6:53 pm
I love the stealthy'ness.
Take some vids of it performing.
Booky
Post by Booky » Wed Jul 18, 2018 10:24 pm
Come on John you tease us with your build then don’t post up dates for a while.
Lo Cash John
Post by Lo Cash John » Thu Jul 19, 2018 11:38 am
Sorry guys but I've been super busy with work and with some repairs on our daily drivers. I did start fabbing up a breather box but it's not done yet and the pics are on my phone.
Hopefully I can post more next week.
