How to tune Water Injection
Moderator: seabeebuggy
buguy
Re: How to tune Water Injection
Post by buguy » Mon Jul 02, 2018 1:44 pm
Glad you got it. That would scare the crap out of me hearing that ping!
GARRICK.CLARK
Post by GARRICK.CLARK » Mon Jul 02, 2018 2:22 pm
Yeah not good. Its an horrible sound. Its the sound of a wallet emptying all its cash. lol.
GARRICK.CLARK
Post by GARRICK.CLARK » Mon Jul 02, 2018 2:56 pm
I've got a direct port water nozzle kit fitted to my manifold's. So 1 nozzle per cylinder. thing is I cant use it due to vacuum sucking the water out on over run. The devils own non return valves are £43 each so £166 for 4. They are set to hold back vac of 16psi. There must be must be a cheaper option out there. anyone no were to get them from.
Clonebug
Post by Clonebug » Mon Jul 02, 2018 3:12 pm
Get a N/C 12 volt by 1/4 NPT solenoid and wire it to open when the pump kicks on....
https://www.ebay.com/itm/1-4-Inch-Norma ... 8264!US!-1
Being that you are in the UK you might need to find on there since your pipe threads are different.
I run two Hobbs switches and two solenoids to keep my water from getting sucked in.
Your other choice is to move the nozzles above the carbs so they don't see vacuum.
seabeebuggy
Post by seabeebuggy » Wed Aug 08, 2018 8:49 pm
water adds cooling but it also adds boost. Water vapors expand very fast. You want to tune the engine to not ping without water. More fuel, more octane, less timing, whatever combo it takes. When you have that, you add water until you feel a power loss. Back it down until you don't. use water to be an extra safety measure and not to cover up problems. You can add meth or Alki if you like. Water over a good tune works great. My engine is 13 or so years old now and its still going strong. I have rebuilt it before the water tuning due to detonation. If your racing and going for max power then I don't know how to help you there.
Dan Dryden
Post by Dan Dryden » Mon Aug 13, 2018 6:09 pm
Pretty sure Devils Own offer a solenoid for around £40. That should stop you drawing water under vacuum.
Dan Dryden
Post by Dan Dryden » Mon Aug 13, 2018 6:12 pm
Clonebug
Post by Clonebug » Mon Aug 13, 2018 11:27 pm
I bought solenoids off Ebay for $25.00 U.S.
sidemarkers
Post by sidemarkers » Tue Aug 14, 2018 12:19 pm
Tuning water injection is fairly straight forward. Aim for using only enough to suppress the knock.
I use about about 30% meth to water ratio.
Keep in mind if you already tuned your fuel map prior to adding the meth/water mix you will run richer when spraying.
GARRICK.CLARK
Post by GARRICK.CLARK » Tue Aug 14, 2018 1:49 pm
Yes thanks guys. Dan so to stop the water getting sucked out the 4 nozzles, 1 per cylinder I'd need 4 solenoids . 70 quid each is too much for me, thanks for the input thou .
Dan Dryden
Post by Dan Dryden » Tue Aug 14, 2018 4:20 pm
No, just the one solenoid is needed. You can fit it before the branching tee to the 4 ports
rubenski
Post by rubenski » Tue Aug 14, 2018 4:30 pm
I was thinking the same thing!
madmike
Post by madmike » Wed Aug 15, 2018 6:43 am
With this cheapass preimeum fuel we have now days I'm thinking about this cuz race fuel isn't cheap :lol:
can this be done to a 'Drawthru?"
GARRICK.CLARK
Post by GARRICK.CLARK » Wed Aug 15, 2018 11:37 am
ok ,1 solenoid I can handle. So i already have the 4 nozzles fitted to the manifolds. The 4 branch is in the middle of the engine near the top pulley,the water pipes from the 4 branch to the nozzles are say 14 inches or so each. wont the vac pull the water out of each pipe up to the solenoid. Is this an issue.
Post by Chip Birks » Wed Aug 15, 2018 1:26 pm
Its kinda like sucking on a straw with a finger on the end. How much of the water can you get out? Especially if you can't collapse it.
