I have a 1600 DP almost turn key engine for sale. The engine has "0" miles with about an hour test run. The guy that had it built for him had it set up to install in a 69 Ghia and it was installed. I sold the body and kept the engine. The hole for the accelerator tube was drilled on the left side of the oilcooler and he cut off the preheat tubes. I have a replacement center section. The engine is new inside and out with new alternator, etc and he put an extention on the carb. I want 1500.00 for it. It also has lighten flywheel.
If you want photos of it email me at [email protected]
1600 DP engine for sale with photo
- foxtail1
