Thing Wheel balancing
How do you go about balancing the wheels on the Thing with original rims?
Re: Thing Wheel balancing
I have (made) an adapter steel ring that I bolt wheel to so that it can be balanced on static or dynamic balancer,works on all 5 bolt rim, pm me for more info.
RK
RK
- rockurob
I have a 73 Thing and a Baja Rat, wide 5 wheels .... I use about 6 oz of 25 grain soft air gun
pellets in each tire/wheel .... works for me .... sorta like what is used on semi truck tires to balance
then but I think they use steel ball bearings or similar bearings for them
