Buggy GP mk1 rebuild pics
Good question letterman. That's life in de islands. For an auto part you can expect to pay four times as much as you guys would pay in the States. Shipping and lots of import duties really add up. The set up worked fine for about four years
Because the buggy was put aside for two years, I had to completely dis and re assemble it. Please wish me luck that I've put it back together correctly.
Thanks for the interest and I'd appreciate any advice or pointers. I've lurked on the Samba and here for a long time and now feel honoured to be part of STF. Makes me want to start another one as soon as I finish This one. (I'll make a lot less mistakes)
It's all part of the learnin' curve! Head on over to the Dune Buggy Archives (www.dunebuggyarchives.com) for more buggy specific questions. It's also a little more active than this particular part of the STF.
Rick
Rick
Thanks Rick,
Yes I've been there too . Unfortunately I did not peruse these sites when I first started this rebuild. How the heck I got through the first build/ conversion I truly do'nt know. That was 17 yrs ago, The 'roll bar' was fabbed from P V C! That was put there just to put a bit of a roof over it.
Hopefully, some pics of the buggy with the final paint applied tomorrow.
Did a bit of money earning today but still put a few hours into the paint prep.
eEvil computers
I will not give up trying but posting pics is a real PIA!!!. Is there a John Muir type tutorial for dummies like me?
Anyway ,the supposedly 'final ' paint job ended up with a few imperfections which were caused by my over exuberant use of the clear coat. So I let it sit for a few days and sanded with 1,000 paper and proceeded to shoot one last final ,'final coat' . DARN! for some reason most of it erupted in 'fish eyes'.
I stopped clear coating the outside @ an early stage but proceeded to clear coat the inside of the tub and that came out perfect. Why? Somehow I believe that the tack cloth some how got contaminated. It was the second time I'd used it and it was not properly sealed. I concluded this because I did not use said cloth on the inside. Sh1t! more sanding ,time and money. "We shall never surrender".
On a more positive note, This morning I was lurking, as usual ,and realised that I had one too many springs in my 009 distributor so proceeded to take the Compufire out fixed the problem and did'nt break one single thing!
I then went to our local place which specialises in bolts &nuts etc and got the engine mounting bolts and stud which I somehow did not have. Luckily I had the bolt which goes next to the starter. Then I went to the place which specialises in hoses and tubes etc and picked up some kevlar reinforced fuel line and some copper fuel line.
The fuel line @ the engine side is installed (apart from the hose clamps which I forgot to get) and the wiring on the engine was also completed. All in all not a bad day. Guess I"ll have to make a trip to the hose clamp store in the near future . Money earning for the next two days, so not likely I'll get much done . Maybe I'll try again with my evil and vindictive photo programmes tomorrow . Later guys.
Here'a a bit of an up date and some funky stuff.
That' my Shadetree dashboard complete with Epson colour printed door. I was experimenting with a funky theme but ended up painting it in flat black. I really do not like the matt black . Any suggestions ?
I scored a turn signal assembly and some various switches from a subaru that a friend was junking. To get the turn signal set up to work, the steering column had to be dropped a bit and i made a collar to fill the space . So now I've got turn signal on the left, hazard light switch and horn button on the right.
My 'Hoover bit"
Printer cover. Think I'll put fuses and relays behind here.
My 'Hoover bit"
To get paint up inside of the tunnel , I took the sprayer nozzle off the HVLP gun and was surprised how far it went ! Sprayed from front and rear and it worked like a charm. I had a nut welded around the drain hole and will be bunging it with a bolt so that i can dump some oil in there when she gets on the road.
Taking a picture was a much better way to see inside of the tunnel also.
Guess I'll also put this up on the paint/bodywork forum also.
