Hello everybodyThanks in advance if you can answer.
Hi I was looking for a 2 solid numbers on type 1 head stud pattern left to right and top to bottom on a stock 1600 or where i can find the figures that are accurate to all
Iam measuring 3.200 across the top studs center to center
Iam also measuring 3.020 top to bottom center to center on the studs
can anybody confirm this or can direct me to a book figure set in stone.Thanks
TYPE 1 cylinder head stud pattern dimensions around 1600 cyl
