Help!
66NCVW
Help!
Post by 66NCVW »
:oops: When taking my engine apart I forgot where this spring went. It's an AS41 case and I have not pulled the oil pressure relief screw out of the case. Could this spring have come out when I split the case? I removed my fuel pump and dist drive and couldn't remember if it possibly came from there? I'm stuck on putting the case halves together until I can identify it for sure. I feel dumb :roll: :roll: Picture of spring next to cam plug for size reference.
Marc
Re: Help!
Post by Marc »
Distributor drive pinion spring. If you have another, this one could've been dropped into the sump at some time in the past and been riding along since then...
66NCVW
Re: Help!
Post by 66NCVW »
Thanks for the fast response!! I can move forward now. :D :D
