Todd Francis (TF-1) case
Moderator: sparkmaster1
MConstantbabble
Post by MConstantbabble » Wed Jun 15, 2016 4:41 pm
Just curious if anyone here has experience with this case for street use?
Thanks!
woodsbuggy1
Re: Todd Francis (TF-1) case
Post by woodsbuggy1 » Tue Jun 28, 2016 9:52 pm
I have no experience with this case but have heard good things about it. One thing that I am curious about it is, what other special parts are required? I know that cam and crank gears need to be changed but what else? What is the total cost when all of the special parts are included?
Kenric
Tinyvw
Post by Tinyvw » Sun Feb 18, 2018 2:34 pm
I am building one over the next year, it's a slow build. ..the dropped cam gear set is the only special part needed, other than that stock parts will bolt right on. ..the gear set is about 175 bucks. ..the case is superior in every way to anything else on the market. ..you can even get the 104mm bore if you want, if you can find affordable heads.
woodsbuggy1
Post by woodsbuggy1 » Sun Feb 18, 2018 6:12 pm
I look forward to seeing your build thread, have heard nothing but good things about the TF-1 case.
Kenric
ridenrace6
Post by ridenrace6 » Mon Oct 08, 2018 9:44 am
who makes the cam and crank gear sets for these?
turbobaja
Post by turbobaja » Tue Oct 09, 2018 6:42 pm
I'm pretty sure there is an option for standard cam location as well if you don't need the added clearance. Then it's just like building a stock case, but way better.
Karl
DON'T QUIT
