Pulling Degree Pulley?
Moderator: sparkmaster1
Ark1
Post by Ark1 » Thu Jan 26, 2017 5:04 pm
What method do you guys use to pull degree pulleys inside the car? Can find a puller that fits. Santana style Scat pulley. Just put it on and its interfering with the tin/oil pump stud; so I can't just bend the sheetmetal out of the way.
Ideas?
Re: Pulling Degree Pulley?
Post by Marc » Thu Jan 26, 2017 5:35 pm
I've never encountered an aluminum pulley which fit so snugly that it couldn't just be wriggled off...you may need to pry it gently away from the case on one side while tugging on the other until it starts to come free.
I suppose a heat gun would help if it won't budge cold...
Post by Leatherneck » Fri Jan 27, 2017 7:27 pm
IF it is on and interfering with the sheet metal seems you'll have to remove said sheet metal to pull it as Marc said.
Post by Ol'fogasaurus » Fri Jan 27, 2017 8:11 pm
Hmmm... I wonder, Al and steel are dissimilar materials assuming it isn't just the access through the tin that the oroblem.
sideshow
Post by sideshow » Fri Jan 27, 2017 9:02 pm
Normally aluminum ones are super easy to remove as they crack at the key way, you could wait for that to happen.
Now if you are in a hurry, why not the common (stock ones will not work as they are two-jaw-ish) aftermarket puller?
http://www2.cip1.com/ProductDetails.asp ... C-C10-7013
Post by Marc » Fri Jan 27, 2017 11:11 pm
Actually I've rarely encountered problems with cracking on the "5-hole" aluminum pulleys, regardless of manufacturer...in my experience it's been the 4-slot ones that self-destruct, I theorize that it's a harmonic vibration thang.
Ark1
Post by Ark1 » Tue Jan 31, 2017 4:59 pm
It's a new scat pulley. They say in the directions to pull it form the center somehow, and not where the belt goes. If i had ran the oil pump studs in another 2.5 turns when i put the engine together it would'n't be an issue lol.
