accelerator pumps
Moderator: sparkmaster1
mlrailguy
accelerator pumps
Post by mlrailguy » Sat Jul 08, 2017 12:53 pm
Both of my carbs need pump adjusted. They do not squirt till at full throttle and I would assume they should squirt as soon as throttle began to open. Do I begin tightening or loosening the nut on rod To achieve this?
You guys have been lots of help with all other questions I've had and I greatly appreciate this.
Re: accelerator pumps
Post by Leatherneck » Sat Jul 08, 2017 3:33 pm
Has the carb been cleaned so you know the ports aren't clogged?
mlrailguy
Post by mlrailguy » Sat Jul 08, 2017 3:44 pm
had them completely apart, lots of carb cleaner and compressed air. I assume they are clean
66brm
Post by 66brm » Sun Jul 09, 2017 6:35 am
Backing the nuts off will give the largest pump stroke therefore the most volume
