1916 Top end rebuild - what should I look out for?
Moderator: sparkmaster1
Dean...
Re: 1916 Top end rebuild - what should I look out for?
Post by Dean... » Tue Oct 03, 2017 1:32 am
Thanks mate
I don't know what the fuel enrichment and plungers are lol I have never seen them, but it's probably what the problem is because I can't find anything else.
Work is a completely different thing.... I was working in community services and I spoke up about stuff that was wrong, and for my good deed I am shown the door. That's fine, is rather do the right thing than to go with the flow, but my confidence has taken a pretty big hit, and this mongrel car isn't helping lol
Sent from my Pixel XL using Tapatalk
Dean...
Post by Dean... » Tue Oct 03, 2017 5:19 am
Update!!
I just finished rebuilding my 40mm Webers and installed them. I start turning the motor over and it starts, but then the left carb starts flooding big time! So I take the top off and replace the needle and seat.
I give it another go, and it starts, and even at the initial settings, it's already running so much better! I get it warmed up, and set the idle mixture, and it's running beautiful! It was getting late so I've called it a day. Tomorrow I'll do the final adjustments.
Thank you to everyone who have shared their advice and support!!! I have really appreciated it!!!
66brm
Post by 66brm » Tue Oct 03, 2017 7:01 am
It's the choke assemblies, typically the cover is taken off and a blank off plate is attached. The pistons in the body stay there but if they move they will richen up the mixture causing flooding and black smoke
Post by Ol'fogasaurus » Tue Oct 03, 2017 10:00 am
Dood... congrats! 8) On to the next problem :wink:
Dean...
Post by Dean... » Fri Oct 06, 2017 3:49 am
I blew 2 oil filters so the next problem happened pretty quickly lol
66brm
Post by 66brm » Fri Oct 06, 2017 6:29 am
Oil control plungers sticking?
Dean...
Post by Dean... » Fri Oct 06, 2017 3:11 pm
I checked them just before I fired it up the first time, but I think I'll be checking them again
What oil do you use in WA?
66brm
Post by 66brm » Sat Oct 07, 2017 6:19 am
Depends if I built the engine or not, typically a 15w40, for street engines, 5w30 for higher performance closer tolerance engines. I always recommend keeping an eye on new engine oil pressures and choose the weight accordingly
Dean...
Post by Dean... » Fri Oct 13, 2017 7:05 pm
15w40 semi-synthetic is what I'm using at the moment. I just installed a new 26 mm pump and blew a Ryco filter!
I've ran 20w60 Penrite some time ago in the motor and had no issues, so I doubt it's the oil, though the old pump was in pretty poor condition.
Dean...
Post by Dean... » Fri Oct 13, 2017 7:09 pm
On a positive, I've almost finished connecting up my DIY Oil Catch Can!
I made it using PVC downpipe. For the hoses I used the stainless steel ones that they use under kitchen sinks. They handle high water pressure so they should cope with a little oil vapour!
I have a line coming from each tappet cover, and I'm going to connect a third line to where the fuel pump used to be. I still have to get a suitable connector. The catch can then runs to the top of each air filter.Image
Dean...
Post by Dean... » Sat Oct 28, 2017 10:59 pm
Update!
I now have the engine running beautiful!! I was blowing oil filters because when I bought new oil pressure and relief pistons and springs, rather than being supplied what I had ordered which was the standard kit, what I received were booster items. Once I finally realised the issue I went and bought a second hand set of standard springs and haven't had another issue since! The car is running sweet as!!!
Thank you everyone who shared their thoughts and provided some advice!
