1600dp budget turbo build
Moderator: sparkmaster1
woolardgarage
Post by woolardgarage » Thu Jun 28, 2018 6:25 pm
Ok here is the build I'm thinking off let me know if there is anything wrong with this build.
Stock case
Stock Crank
Stock cam
Stock Pistons and barrels
041 Heads
Forged 1.4:1 rockers
VW650 dual Valve springs
Supergrip snakeskin valves
Chromoly pushrods
Titanium Retainers
Lightweight 8 dowel flywheel
Chromoly Gland nut
CB performance Turbo header
Dellorto side draft 40 carb
Used t25 or t3 turbo rebuilt from like a saab or subaru
MSD 6AL box
MSD 2step
Pentronix flamethrower Distributor
Bosch blue 009 coil
Might have left out a few parts. This is going in my 1969 standard bug for some mild street fun. I want to make between 120-180 hp to the crank at 7-14psi (I'm trying to be as realistic as possible). I also want to redline at 5.5-6k. Let me know if any of this seems like it will work together or if my goals aren't realistic. Any advice is greatly appreciated.
Re: 1600dp budget turbo build
Post by Chip Birks » Thu Jun 28, 2018 11:52 pm
Why the stock cam? Probably a little wild on springs and such there are folks with bigger cams making more power with less.
sideshow
Post by sideshow » Fri Jun 29, 2018 7:52 am
Why not the stock cam, dual patterned, great low end, the most successful grind ever offered?
I would consider bee-hives or something with steel retainers,aluminum/titanium ones wear out faster.
Post by Chip Birks » Fri Jun 29, 2018 9:17 am
I don't think I worded that well. I meant vw650s are probably a little wild, if using a stock cam. I guess I look at it like if its open and you are looking at it and considering any kind of performance why not change it.
woolardgarage
Post by woolardgarage » Sat Jun 30, 2018 2:18 pm
Every forum I've looked through I thought vw650s are the way to go they are all i hear about
woolardgarage
Post by woolardgarage » Sat Jun 30, 2018 2:20 pm
And what cam should I get if I upgrade from stock I want a good low to mid power range
