twin port manifold gaskets... metal or card type?
Moderator: sparkmaster1
kiaora73
Post by kiaora73 » Sat Sep 01, 2018 7:04 am
Sent from my SM-G925F using Tapatalk
sideshow
Re: twin port manifold gaskets... metal or card type?
Post by sideshow » Sat Sep 01, 2018 9:55 am
A stock center mount(braced by heat riser, case stud) rarely moves, so one uses the stock crush gaskets and it works great. Anything dual you are likely going to need to remove a few times (get the engine into compartment or spark plugs out) over its life time, I would use the thick quality paper type.
It is application dependent.
vwo60
Post by vwo60 » Tue Sep 04, 2018 9:06 pm
I never use any gaskets, just loctite 518 and have never had a failure.
Lingwendil
Post by Lingwendil » Fri Sep 14, 2018 10:06 am
Metal for stock, fiber/paper for duals. I smear the paper type with SuperLube on either side, let it soak in a moment, and wipe off the excess. I find that this keeps them "fresh" for a very long time, and they never stick to the head or manifolds anymore this way.
