Replacement camshaft for WBX?
tmatre
Contact:
Post by tmatre » Wed Sep 29, 2010 4:36 pm
I am looking for a replacement camshaft for WBX, but can not find anything but reground (vw heritage)
Do you know of anyone selling new DJ camshafts? I bet they are expensive...
Other alternatives for hydraulic lifters?
Anyone using the CB performance 2251 hydraulic cam in WBX?
How do this perform in a camper compared to the stock DJ camshaft?
fastback
Contact:
Re: Replacement camshaft for WBX?
Post by fastback » Wed Sep 29, 2010 4:49 pm
2252 should be ~ to the stock DJ.
or they have 2253 and 2254.
tencentlife has some more info on using these.
AMBROSIA
Post by AMBROSIA » Thu Sep 30, 2010 10:28 am
I'm using the 2252 in my DJ engine.
Pulls like a train, nice bit of kit.
Shame you have all the extra import costs :evil:
buildabiggerboxer
Post by buildabiggerboxer » Thu Sep 30, 2010 11:32 am
D.J camshaft. I have these new, genuine v.w german manufacture. also cam followers.
tmatre
Contact:
Post by tmatre » Sat Oct 02, 2010 4:37 pm
I have found some new posts...
viewtopic.php?f=37&t=122471&hilit=cooler&start=15
2280 may also be used with hydraulic lifters, more lift...
tencentlife:
2.2 litre wbcx.. 94hp @ 4550, 130ft.lb. @3250. Rear Wheels
Torque abowe 120 (162NM) from 2.4K to 4K
2251 Duration 266° / Dur. @ .050" 210° / Lift @ cam .276" / Lift w/1.1:1 Rocker Arms .303"
2252 Duration 270° / Dur. @ .050" 214° / Lift @ cam .298" / Lift w/1.1:1 Rocker Arms .327"
2254 Duration 308° / Dur. @ .050" 236° / Lift @ cam .319" / Lift w/1.1:1 Rocker Arms .350"
2280 Duration 274° / Dur. @ .050" 222° / Lift @ cam .359" / Lift w/1.1:1 Rocker Arms .394"
I think I will go fo the 2280 :-)
tencentlife
Contact:
Post by tencentlife » Mon Oct 04, 2010 11:03 am
Of the few cams I have tried in these 2.2's that's the one I would suggest first, it is overall the torque monster. If you use stock double valve springs and 1.1 rockers, you'll want to shim the springs up .060" to avoid any valve float as it goes over 5k rpm. 1.1's put the valve lift right around .400" which in my experience is the sweet spot with these heads as stock, that's where the intake works best for torque. I've increased the intake lift over that amount and it kills the low-range torque. I used 1.25's for awhile but wouldn't even think of using ratios on the 2280 anymore, the ramps are just too aggro on this cam, but that's that fast lift that makes the torque.
I've run the 2252 in several engines, it is closest to stock performance of the ones named here so far, tighter LCA so idle isn't as smooth but the low range is good, it holds good mid-range torque too for highway hillclimbing. But once I tried the 2280 I have used it in most of my engines since then (about ten have it, including my daily which has about 30k on this cam and I just had the lifters out, things look good).
I also used the 2254 for about a year, it would be a great cam if you had a different FI that would allow revving to 6500, but it's just coming into its own with the stock FI when the fuel cut hits at ~5400, although if you keep the intake lift low it also has pretty amazing off-idle torque, kind of odd, it shouldn't, but it does.
I've found the hydro lifters will run on a lot of solid-grind cams as long as you spec them out visually first for edge interference. I've seen zero troubles so far, if anything they work better. Of course your oiling system needs to be tip-top for good hydro operation, the best thing to do is have external oil cooling to cap temps at 230F and run a light baseweight oil, like 5wXX.
Trying out a couple new cams lately and will probably be adding some data to the cam data thread sometime soon. I just build Vanagon engines so I'm in search of smooth performance with lots of low-mid range torque, so my impressions might not be that helpful for people building race or sandbuggy engines or whatever else.
WBX Man
Post by WBX Man » Thu Oct 07, 2010 3:12 am
Did anyboby try the 2236 ?
2236 Eagle Racing Cam - Adv. Duration 280° / Dur. @ .050" 236° / Lift @ cam .339" / Lift w/1.1:1 Rocker Arms .372"
I still have one I would like to try... :P
fikmyk
Post by fikmyk » Wed Jan 18, 2017 4:05 pm
Looking for advice... my T3 DJ has broken camshaft, I'm looking for replacement as stock is not available and all used one that I found are in bad condition. I want more less stock performance without any changes in lifters, SCAT, adjusters. I travel mostly 50-75 MPH on motorways and I have Vanagon Joker 2.1 DJ bit heavier that normal one (pop-up roof). Can you advice which camshaft would be best? I was thinking about CB 2280 or CB 2252...
Post by Piledriver » Wed Jan 18, 2017 9:28 pm
From memory a Webcam 86 is roughly equivalent to a late MV cam, don't know that the DJs had.
Given press in T1 lifter bushings can be had cheap these days, there should be a lot more good choices.
AMBROSIA
Post by AMBROSIA » Thu Jan 19, 2017 5:37 am
If you're uk based a company called 'The Engine Shop' sells newly made camshafts suitable as replacements.
http://www.theengineshop.info/acatalog/ ... 9TES1.html
Jim sells several variations including performance so perhaps give him a call to discuss what you need.
They are uk made iirc.
I was originally going with one of his fast road cam's:
Duration 290 degrees
Lift @ cam .289
In the end i wanted more hp so went the bush insert route and solids.
