How many boost can i give to a wbx mv
Pictures
http://www.keversite.nl/fotoalbum/my_ph ... 990&page=1
Andre
wbx mv boost
Re: wbx mv boost
hm , nice photo. i have mv too and i'm looking for instalation from some car with turbo.
i have now turbo T3 from volvo i think and i can buy turbo from truck fl615 garret a/r50mm.
some guy have this turbo in 1.8 16v golf mk1 but it wake up something about 3500-4000 rpm's.
I see yours is big too. from what car is this?
Re: wbx mv boost
Jabcok20,
i use a Borgwaner 7g9n 6k682 ae turbo.
I don`t know the spec or from what car it is, we think from a ford.........but.......
Anyone knows how many pressure can i use without risk for my engine?
Engine:
WBX type MV original
KMS motor management system
Hydro lifters
Camshaft CB type 2252: Adv. Duration 270° / Dur. @ .050" 214° / Lift @ cam .298" / Lift w/1.1:1 Rocker Arms .327"
I heard that 1,8 bar is oke, but for i destroy the engine, i want to know for sure.
My goal is, a lot off power and drive fail safe.
Andrè.
Engine:
Hydro lifters
Andrè.
- fastback
Re: wbx mv boost
i can only give u advice from my own testing and tuning
1 bar on 98okt RON is safe
1.8bar on E-85 has been done
all with stock wbx pistons and rods.
stock pistons are fragile so be easy on tuning/mapp'ing
Re: wbx mv boost
THx very much for reply. it is very usefull;D
I have more questions, how high can spin a stock mv? With and without turbo. Where is that safe border.
what oil i must take when i run this engine with or without turbo?
I think 1 bar will be enough for me( for a first couple of month:P ). How much hp can i achieve from stock mv on 1 bar?
Sorry for my english;)
- joop
Re: wbx mv boost
Hoi Andre,
Thanks for trying to break your engine! It pulls and shifts great!
My neighbour laughed, but I do not know if he liked your driving style when you drove home
If you want it to stay in one piece don't go over 1 bar. and keep an eye on lamda readings and ignition timing and drain the 95RON.
I got some (50L) 95RON for free yesterday and I had to retard the ignition because it gave a nasty ping.
Your exhaust and car is noisy so you may not hear the pinging
jabcok20,
With turbo there is no need for very high revs if you have a good turbo setup.
without turbo my DJ vanagon revs easy to 6000rpm but when "touring" long trips on the highway I don't go over 5500rpm.... this is high enough to get a BIG fine.
Joop
jabcok20,
Joop
Re: wbx mv boost
what you mean pingng?
i don't speak english very well so i don't know that word.
So we have 95 and 98 (no Pb) petrol here in Poland, which will be better?
- joop
Re: wbx mv boost
hammer-like shock waves
detonation = DETONACJĘ
98 is beter to prevent DETONACJĘ but it is even more expensive....
Re: wbx mv boost
Ok thx i understant. so you mean detonation from bad miksture of air nad petrol or too much petrol. soo a car must be setup for inject and turbo. or i think do we can change map of timing and move it later?
