Hi guys ,
i'm close to start my Oxyboxer engine building ,will be a 4" x 78 and Hp goal is around 230, street&strip use ,
and i wondering what kind of clutch disc and pressure plate you run on your engines with Wbx crank and 228mm flywheel?
and is a 200mm T4 flywheel compatible with wbx crank pattern ?
thanks in advance for your inputs
Eddy
228mm clutch ?
- fastback
Re: 228mm clutch ?
yes the type 4 is the same pattern.
I think the stock disc will hold.
used the stock clutch in a oval beetle with a turbo WBX 1,9 with ~200LBS/ft of torque.
as it is the torque that makes it lip , not HP
http://kennedyenginc.com/228mmClutches.aspx
Re: 228mm clutch ?
yes ,you're right it's better to talk about torque ,i expect around 220Lbs/ft at peak , MS230 help's on this N/A engine,
thanks for the infos
