Pulley options?
Pulley options?
Hi all,
i wonder what kind of crank pulley is most appropriate on my oxyboxer ,
i've got two sets in stock ,an aluminum BMD serpentine belt and a classic steel damper with "V" belt,
i'd like to use the BMD one ,but it's really light ,and i'm worried about bearing wear,
however when i see my 78.4 DPR wbx crank and his big counterweights ,i think that a damper is not needed like on a T1 crank ,
let me know what's better?
thanks
Eddy
thanks
Eddy
- sideshow
Re: Pulley options?
Whatever one allows the use of the wasser crank seal
Re: Pulley options?
Hi,
both are sand sealed and balanced ,so no problem,
the question is more about a possible quicker bearing wear with the aluminum pulley ,
thanks
thanks
- Stripped66
Re: Pulley options?
The Type 1 sand seal has a smaller diameter than the WBX seal.
Re: Pulley options?
Hi,
thanks for advices ,
i solved the question with this custom pulley :
Re: Pulley options?
where did ya get that pulley at and how much? i want one for my WBX.
Re: Pulley options?
Hi,
at WPK (France) : http://www.wpk-racingshop.com/catalog/i ... 9ee0da124b
several size in stock ,aluminum or steel,
contact here: [email protected]
Re: Pulley options?
There was a single wbx pulley used on synchros and also in Europe. What I did was take a cast wbx triple pulley and had the two outer pulleys removed on a lath. It may not look as nice as the one above but it works. I had it dynamically balanced with the rest of the spinning parts. My van does not have PS or A/C so I wanted to shed the extra weight. I could not find any other alternative when I was looking two years ago.
http://images.thesamba.com/vw/gallery/pix/1048188.jpg
Pascal
84 Westy
84 Westy
- Devastator
Re: Pulley options?
"WPK racing shop".
Cool. apparently I can read french.
Devastator's Build Thread
Sandrail
going fast enough."
Mario Andretti
Sandrail
going fast enough."
Mario Andretti
Re: Pulley options?
two ways out of the pulley problem, for an oxy, just turn down the oil scroll on suitable T1 pully, just machine untill its gone, still fits the wasser oil seal perfectly, you can also use the longer wasser pulley hub if you're staying with the wasser water pump, just remove the rivets and modify a suitable pulley, fastback has Photos of his version on here somewhere.
