Hello all,
Are there any baseline settings for Megasquirt on a 2.1 US spec WBX?
Megasquirt baseline settings
- DORIGTT
Re: Megasquirt baseline settings
My apologies for asking...go back to sleep now.sd
did you find what you needed?
- DORIGTT
Hello Piledriver,
I did some more digging and I believe I've found the answer in the baseline start-up protocol. I was looking for the settings from someone who had specific parameters for a stock WBX to use as a baseline, but I guess going through the basics gives me more 'seat-time' tuning the setup.
Thanks for checking in.
i can give you my tune to work with. i got a WBX with ms1 3.57. my tune starts right up even when super cold. it still needs a little work, but it close and a good starting point. im also running stock injectors, and stock WBX dizzy. let me know if you need it.
- joosep
I think I would need it one day
What type of sensor is in the stock dizzy? what type of wheel it reads?
Did U noticed some power increase with MS? few horses should be stuck into maf How much are the stock injectors open in WOT?
HAL sensor with "4 window" wheel
MSnS Mode with one trigger per spark event
http://msextra.com/doc/ms1extra/MS_Extr ... l.htm#hall
This is how I modified my distributor (locked)
http://forum.earlybay.com/viewtopic.php ... r&start=80
