OXY newbie
58Dub
Re: OXY newbie
Post by 58Dub » Wed Mar 19, 2014 11:17 am
nice to see some progress being made....
grelland
Re: OXY newbie
Post by grelland » Wed Mar 19, 2014 12:16 pm
nice :)
bugtub
Re: OXY newbie
Post by bugtub » Thu Apr 03, 2014 7:50 am
I see you have machined where the barrels sit. Have you already worked out what the deck height will be or is there just a set amount that needs machining off?
For mine as the water jacket needs machining off any way I was thinking of taking 1mm off this face now, then adjusting the deck height with shims. Do you think 1mm would be enough or is it a bad idea?
58Dub
Re: OXY newbie
Post by 58Dub » Thu Apr 03, 2014 10:55 am
My understanding (im not doing the machine work) is that once the waterjackets are machined off, and case decks are made even, the piston deck height is set by shortening the cylinders. The cyls are shortened because the engine case is wider that a normal Type 1 case.
58Dub
Re: OXY newbie
Post by 58Dub » Tue Jun 03, 2014 7:02 am
Getting closer to getting my parts back home. Rocky sent me a pic of setting the deck height... and I think that should be it.
58Dub
Re: OXY newbie
Post by 58Dub » Tue Jun 24, 2014 7:33 pm
Got the rest of my parts back. Looks good. Need to collect a few more $$$ for a few more parts and it will be time for assembly. The engine case work was done by Rocky Jennings and the crank was done by DPR.
58Dub
Re: OXY newbie
Post by 58Dub » Wed Oct 28, 2015 5:18 pm
slow progress, but engine mock up has gone well... and parts are now sent out for coatings. Thermal barrier coatings on the piston tops, combustion chambers, exhaust ports and valves and low friction coatings on bearings, and piston skirts.
