RIP WBX
turner
RIP WBX
Post by turner » Thu Aug 22, 2013 3:28 pm
The end of my good going 2,1 160hp wbx on SPA Circuit 2013 at 7000rmp.
My friend Jürgen an i build it from a 100000km engine in 2006.
6000km digital driving up to 7500rmps on race and hillclimbing.
Jürgen desinged the cam by himself,its a 328 Degrees with 12,8mm lift.Fedded thru 48 idfs with extensiv welded mainfolds.
The rods are orginals rebuild,loss weigth,shot-peened and well-balanced.
Heads are ported by him,the Valves are stock,but flow-through turns.Exhausted is a A1 <perfomance.
The whole story from my 1302 superbeetle:
http://www.pixum.de/meine-fotos/slide/album/1084739
on the race:
https://www.youtube.com/watch?v=VF3nMN_ ... D5fH-LZYaA
speakers on:-)
the future will bring more ccm an hps.
enjoy it,
cheers from good old germany
Turner
andy198712
Re: RIP WBX
Post by andy198712 » Thu Aug 22, 2013 4:10 pm
ouch!!
Steve Arndt
Re: RIP WBX
Post by Steve Arndt » Thu Aug 22, 2013 5:16 pm
Did it drop a valve first, or throw a rod?
fastback
Re: RIP WBX
Post by fastback » Thu Aug 22, 2013 5:24 pm
cool build :) sorry about the new went hole though.
fastback
Re: RIP WBX
fastback
Re: RIP WBX
Post by fastback » Thu Aug 22, 2013 5:28 pm
What happend?
Any special wear on the thrust side on the cam bearing when using helical camgear ?
any dyno papers :)
Stripped66
Re: RIP WBX
Post by Stripped66 » Thu Aug 22, 2013 7:42 pm
Stock oil pick-up?
Passatman
Re: RIP WBX
Post by Passatman » Thu Aug 22, 2013 7:52 pm
Now i am scared. I have a 2.1ltr i want to build with rebuilt stock rods. I guess i will do some more thinking on that.
Hmm! 160 HP from a 2.1ltr nice. Were you using stock pistons.
turner
Re: RIP WBX
Post by turner » Fri Aug 23, 2013 1:57 pm
Sorry,the rods live :shock:
the Valves too,ok the outlet is a little bit out of the middle
one lifter is cracked
Yes,standard pistons and standard oil pick up,but all clearanced.
The piston pin were machined inside conical,the pistons well-balanced,an cut to same deck high.
The piston are change to floating pistoin pins.
We think that one circlip broke an the pin comes out an damage the cylinder.
Then the piston broke in too pices and make a big hole :twisted:
No extensive wear on the thrust side.
with the old to small exhausted and 009 ign.Now with A1 and 1-2-3 Ign.
Sorry for my bad language
Turner
fastback
Re: RIP WBX
Post by fastback » Fri Aug 23, 2013 3:06 pm
Ahh
Yes the stock rods are really strong . I have used them in all my builds (except one engine) with turbo and 7000+ rpm.
Just replace the rodbolts and check for out of round.
Most likely it is crankflex because high RPM so the pins work side to side.
Seen it on the engines that has been frequent into 7000 RPM mark.
Had to use Dremel to get the pins out!
Maybe a DPR crank with the bigger type 4 center can minimise flexing
Passatman
Re: RIP WBX
Post by Passatman » Fri Aug 23, 2013 5:14 pm
Tuner did you re-use the original rod bolts or did you change them to t1 or t4 rod bolts.
Passatman
Re: RIP WBX
Post by Passatman » Fri Aug 23, 2013 5:17 pm
fastback wrote: Maybe a DPR crank with the bigger type 4 center can minimise flexing
Fastback will your 84mm stroke waterboxer use a t4 centre main crank. If so is that bmw conversion bearing a direct drop in.
fastback
Re: RIP WBX
Post by fastback » Fri Aug 23, 2013 5:29 pm
yes i have typ4 center
Scat has adapter bearings
Passatman
Re: RIP WBX
Post by Passatman » Fri Aug 23, 2013 6:04 pm
Fastback can we talk via the message here on this site. Need to ask some serious questions.
turner
Re: RIP WBX
Post by turner » Sat Aug 24, 2013 1:07 am
Passatman wrote:Tuner did you re-use the original rod bolts or did you change them to t1 or t4 rod bolts.
No,we use new wbx rod bolts in 2006.
But one engine befor this happens:
i heard from several engines with broken rods on the 3rd Zylinder.
Must be a common problem on wbxer :twisted:
Often the lubrications is broken down.
The next engine is in work
Will takes time and much more money.
More ccm and bigger valves,ev. chanching the cam to one more aggressiv.
Jürgen desinged a new one :mrgreen:
Transporting the red tomato to race:
having fun with Jürgen 911 and turner typ3 in the dolomites this year
see you
turner
