thrust washer bore
DRED
thrust washer bore
Post by DRED »
Hello,
Can someone help me an tell me the trust washer bore and depth in the 3 piece rear main Bearing engine case.
I'm trying to fit à wbx crank in a type 1 case with BMW bearings and want to use wbx thrust washers if it' possible.. i want tout know if the samedi housing is machinable. ...
pocketrocket
Re: thrust washer bore
Post by pocketrocket »
74mm x 1.7mm
DRED
Post by DRED »
Thanks a lot pocketrocket..seems to be bigger than what i was expecting (the thrust set i have at home have 73,1/73,2mm diameter). i was worried about concentricity and having the more tight housing possible, to avoid "hula hoop" , but doesn't seems to be so important..
