4 inch bore engine
Passatman
4 inch bore engine
Post by Passatman » Sat May 07, 2016 10:20 am
Ok guys i have seen where it was mentioned here that the oxyboxer retains it's stud location when going 4 inch bore.
Has anyone done this engine as a daily driver and how was the performance, did the engine cool well? I am thinking about doing a 4 inch bore daily driver.
Re: 4 inch bore engine
Post by Marc » Sat May 07, 2016 1:29 pm
It's my understanding that if you want to run 4" cylinders with decent wall thickness the studs still need to be moved out a little. One of the modifications Rocky Jennings is set up to do (he moves 'em .050"). I'd definitely ask for his input, he's probably seen more oxyboxers than anyone.
http://www.rockyjennings.com/
Passatman
Post by Passatman » Wed Jun 15, 2016 7:14 pm
I will be contacting him in October.
ecksrash
Post by ecksrash » Thu Sep 15, 2016 2:09 pm
Any more info Passatman??
Passatman
Post by Passatman » Thu Sep 15, 2016 7:21 pm
Ecksrash no info yet i haven't approach rocky as yet. I should have some info in october.
Passatman
Post by Passatman » Sun Apr 16, 2017 3:08 pm
I approached rocky and he isnt too fun of the idea. You might be lucky in checking with brothers machine shop, spoke to those guys sometime ago and the guy on the phone said they had done a 4 inch bore oxyboxer for a customer.
I will be doing a 94mm bore engine instead as the options for a 4inch head is costly. My choice of head was JPM 230 heads.
Post by Chip Birks » Sun Apr 16, 2017 11:09 pm
Rocky didn't like the 4 inch bore idea? I thought that was half the benefit of using the wbx case for these oxy builds...why doesn't he want to do it?
Passatman
Post by Passatman » Mon Apr 17, 2017 7:41 am
It's my guest that the cost of machining would be prohibitive. What i wanted to do was use a waterboxer head on the oxy engine bottom half, something similar to the porsche 959 engine.
Post by Chip Birks » Mon Apr 17, 2017 9:53 am
Like a water cooled head with aircooled cylinder.
Passatman
Post by Passatman » Mon Apr 17, 2017 10:35 am
Yes that's it.
Passatman
Yes that's it.
