remove head studs
bugtub
remove head studs
Post by bugtub » Tue Jan 31, 2017 7:58 am
Trying to remove head studs. Soaked the case in release oil, heated the case up to 240c about 460F squirting in more high temp release oil and still had four of the studs snap off
madmike
Re: remove head studs
Post by madmike » Tue Jan 31, 2017 8:43 am
I screw a nut down flush with stud so I don't screw up the threads, smack/ tap it with a hammer , that should help loosen them , Madmike
bugtub
Post by bugtub » Wed Feb 01, 2017 5:41 am
Thank Madmike. I did try that as well. I’m now in the proses of drilling the four studs out found although the studs have tensile strength they are quite soft and easy to drill out
