Wasser locks up after running but then loosens up 30 secs later
bratjie
Post by bratjie » Thu Jul 27, 2017 5:42 am
Hi guy's, need some advice please, I have rebuilt a few wbx engines before and even run a 2.1 Turbo in my beetle. I have overhauled a 2.1 standard sizes on case crank & sleeves. When the case came together the crank turned freely by hand. I installed the engine and ran it for half an hour at idle. Then started revving up slightly to check for smoke, knocks, etc,etc and the engine locked up. however after 30 sec's the engine turns freely and will start first time and idles perfect. I reopened and saw that the centre main bearing caps have worked a little harder than the rest but nothing out of the ordinary, cleaned all up, polished the crank, fitted new mains. Now it will idle up to half an hour with 80deg normal, .5 bar oil press at operating temp. still does the same, locks up after half our. If I keep revs at 2300rpm it will lock up up after a minute. 1 minute later it will start up first click and runs like nothing ever happened but half an hour later, same thing. Using 20 W 50 Castrol as in all other builds. anybody had an experience like this before? Also running 1.9 carb on customers request. Please help!
jackstraw
Re: Wasser locks up after running but then loosens up 30 secs later
Post by jackstraw » Thu Jul 27, 2017 9:38 pm
stick or automatic. crankcase pressure. rod offset. oil passage block. vapor lock.
try to post a video.
Dan Dryden
Post by Dan Dryden » Sun Jul 30, 2017 4:22 pm
Could it be something to do with the valves or cam timing rather than bearings?
buildabiggerboxer
Post by buildabiggerboxer » Fri Sep 08, 2017 3:14 pm
oil pressure is low at .5 bar? and i suspect your tight on crank endfloat, assuming B type thrust shims, it wont show on the No1 bearing as it would on early 1.9 bearings, stack the two problems together and youve got a result. regards BBB.
