Page 3 of 7
Re: Update and improvements on my Oxy build
Posted: Tue Jan 30, 2018 7:15 am
by grelland
flat4olsen wrote:
Tue Jan 30, 2018 6:52 am
Sharp eye :-) I´m in Denmark. I love the wrinkle finish,- my wife hates me, when I put it in her oven, though
I'm in Norway, btw
Posted: Tue Jan 30, 2018 7:19 am
by flat4olsen
I know :-) I have been following your impressive work here!
Posted: Tue Jan 30, 2018 12:53 pm
by grelland
flat4olsen wrote:I know :-) I have been following your impressive work here!
Sent fra min SM-G950F via Tapatalk
Posted: Tue Jan 30, 2018 5:27 pm
by grelland
I am converting to black wrinkle finish
Posted: Wed Jan 31, 2018 3:53 pm
by grelland
Special feeling when the next generation has both the skills and access to equipment you always wish you had yourself ;)
Here is a shot of my son setting up the oil pump for making o-ring grooves:
And when he was happy, he started producing chips:
And here is the result:
So with o-ring sealings on both sides of the ports, I hope my oil pressure/temp issue will be even a little bit better than last year
Posted: Thu Feb 01, 2018 4:33 pm
by grelland
Another productive afternoon in the garage. My son worked on his own car today so I was on my own.
But I wanted to fit the lower cooling tins, so I found an old set in the parts bin and started fitting them to the engine:
After some grinding, I took them for a round in the blasting cabinet:
Then a lick of etch primer and flat black paint
Posted: Sun Feb 04, 2018 12:00 pm
by Dan Dryden
Having access to a lathe and other machining tools is fantastic. My sons are aged 2 & 6 years, so not quite ready to start helping me in the garage yet.
Posted: Mon Feb 05, 2018 4:00 am
by grelland
The one on the left in this picture is the one that now has his own car and is doing the machine work for me ;)
So start them young ;)
Posted: Mon Feb 05, 2018 6:12 pm
by grelland
I can't get the wrinkle finish right....
Posted: Tue Feb 06, 2018 12:43 am
by flat4olsen
How do you do it? I do a light coat, let it dry for about 15 min them do the thickest coat I can apply without runs. Then I heat it in an oven at 100 Celsius for about an hour. The stuff i can’t fit in the oven is placed under a UV light for an hour or more. The heat is very imported for getting the finish right. Even distribution of the heat is difficult with the UV light, but changing the angle of light a few times works ok.
My finish after heating:
Posted: Tue Feb 06, 2018 3:54 am
by grelland
Thanks, the oven is not large enough for the large parts, but UV-light was a good idea :)
Posted: Wed Feb 07, 2018 10:11 pm
by sideshow
Still in love with the trigger flywheel
Posted: Thu Feb 08, 2018 7:31 am
by grelland
by grelland
Posted: Tue Feb 20, 2018 8:57 am
by grelland
I gave up the wrinkle-finish and went back to hammerite...
Other than this; I am waiting for some parts so I can do the final assembly before spring comes ;)
