Oxy crankcase ventilation
grelland
Post by grelland » Wed Feb 28, 2018 2:33 am
Guys,
Looking for some advice on crankcase ventilation.
For the last couple of seasons, I have run a very simple setup with a Berg breather box and a AN-10 hose to an adapter in the distributor hole in order to balance the left and right side case halves:
I am planning a change in the air filter setup, so I will not be able to fit the Berg tower any more.
So to the question:
Is this left-right case half hose really necessary? Can I get away with using a simple oil filler like this:
And then a breather box/catch tank on the firewall?
Are there any other considerations with an oxy case vs standard type1?
bug66
Re: Oxy crankcase ventilation
Post by bug66 » Wed Feb 28, 2018 5:22 am
Put that filler tube in a lathe. Turn it down to 40mm, use 40mm hose to a custom breather box with a 40mm airfilter from Biltema..
2165cc T3/T4 turbo, DTA S60 on E85.
Boost was created only to make people smile, and make power! 8)
10.626 @ 132mph SCC2016
10.407 @ 134mph SCC2017
flat4olsen
Post by flat4olsen » Wed Feb 28, 2018 2:31 pm
My engine is pretty much identical to yours. I vent from the valve covers and from the oil filler (I run an OEM Mexican generator pedestal) to a breather box on the firewall. No problem with excessive pressure or oil leaks. I think you will be fine with the oil filler shown above.
Don´t throw your Berg breather away. Just send it to me, and let me throw it away for you :-)
grelland
Post by grelland » Wed Feb 28, 2018 4:40 pm
Hehe. Thanks guys. No need to overcomplicate then ;)
Just for curiosity, flat4Olsen. Is it necessary to vent the valve covers? I have not done that on any of my last builds.
flat4olsen
Post by flat4olsen » Thu Mar 01, 2018 8:54 am
I honestly don’t know. Some say yes and some say no. It can’t hurt, so I just did it to be safe.
Do you want my address so you can send the Berg Breather? 😂
grelland
Post by grelland » Thu Mar 01, 2018 11:24 am
bug66
Post by bug66 » Thu Mar 01, 2018 12:41 pm
The logic of not breathing the valve covers are that the oil shall go down the 4 push rod tubes. Not the ventilation.
That little breather nipple is no way near enough. A stock 1600cc Type 1 engine has a lot more ventilation..
bug66
Post by bug66 » Thu Mar 01, 2018 12:46 pm
And it does not matter if the breather box on the firewall is large, if the bottleneck is at the engine side..
flat4olsen
Post by flat4olsen » Fri Mar 02, 2018 7:13 am
I am not going to argue about the logic of breathing the heads. As I said, I don’t know if it is needed. I know Porsche did it on the 914 with 2.0 l engine, and I think they did it for a reason. If it works for Porsche I have no reason to question the funktionallity.
bug66
Post by bug66 » Fri Mar 02, 2018 7:18 am
Did Porsche vent both sides, or just one side?
One side fills up with oil, the other doesn't..
flat4olsen
Post by flat4olsen » Fri Mar 02, 2018 9:40 am
