Joxracings part stash**Misc parts**
Joxracing
Post by Joxracing »
Thought Id thin the stash out a little bit, need some money for the baja.
Red fan shroud $30obo?
Tins, decent shape just dirty $15 a set?
Shifters $5 each?
DP Heads, Need rebuild. $25 each, 50 for 2?
old alumninum power pulley, $20?
Generators, with backs, 1 with fan. $15 each? not sure if they work
Gen. stand. $7?
Solex 34 pict carb, looks good, may need rebuild?
$30?
Stock oil coolers, have 3 of them, $10 each?
Holley 2bbl, needs rebuild. otherwise great shape. $50?
Another Holley 2bbl. $50?
(have another holley and a motorcraft carb, about same shape)
Stuff to turn type 3 case into an upright case. $15 takes all?
Stock pulleys, in good shape. $5 each.
2bbl carb manifold, decent shape, just needs a cleaning. $25?
Stock manifold, ok shape, heat risers broken off. $10?
3 sets of DP manifolds, all good shape. $15 a set?
Thats about it, have other parts, so if you need something, just PM me and i might have it.
All prices are neg.
Shipping to the lower 48
MQT, MI 49855
Thanks!
CopperBaja
Post by CopperBaja »
Should put this over in the T1 section. ;)
woodsbuggy
Post by woodsbuggy »
Hello,
Do you still have the 2bbl intake? If so How much shipped to 46772(NE IN)
Kenric
CopperBaja wrote:Should put this over in the T1 section. ;)
Done and bumped!
Turbinepowered
Post by Turbinepowered »
You wouldn't happen to have a complete set of cooling tin that's not holed kicking about someplace, would you? I know the SB is missing some of the smaller bits, and the cylinder tins are looking pretty ragged.
Shroud's in good shape though, so I don't need that piece.
Joxracing
Re: Joxracings part stash**Misc parts**
Post by Joxracing »
still have most of this crap..
noticed these prices are kinda high...
pm me if you see something, and make me an offer.
TromBug
Post by TromBug »
Is that aluminum pulley significantly ligher than the stock one? If so I might be interested in it.
'78 Super Convertible restoration in progress!
Joxracing
Post by Joxracing »
yeah, you can deff. tell the difference.
requieres a smaller belt..
