I am working on my DTM install and need a "late model" fan. How can I identify a late model fan? Is there an identifying dimension/measurement? Thanks.
doc
Late Model Fan
- slowtwitch
- dstar5000
35mm vrs 37mm blade width will identify a late from an early.
You get it installed?
Don
Don
"Let me say it as simply as I can: transparency and the rule of law will be the touchstones
- doc
- Site Admin
I had not seen the last three replies. Sorry. Been a little off my feed lately.
I have two fans, one clearly taller than the other as they lay on the backing plates. They are essentially the same diameter over all and essentially the same overall height. The smaller one has eight holes, evenly spaced, in the backing plate. The "taller" fan has one smaller drilled hole in an otherwise solid backing plate. Neither has marking that I can find. Both have 28 vanes.
The measurement of the smaller one, measured from side to side across a fan blade, on the outside is 1.257" or about 32mm.
The measurement of the "taller" one is 1.468" or about 37mm.
So, this taller one seems to be the one, wouldn't you agree?
Thanks again. No, Don, I do not have it installed yet, but I do have the DTM fitted up pretty close and am still collecting final parts. It's getting pretty exciting!
doc
doc
