Econo Header questions whithin
- Ephry73
Jake,
I was wondering if the econo header comes with the mating flange for the muffler already welded to it, or if it comes separate to let the customer modify the installation. Also, I wanted to know if any of the Magnaflow mufflers on the store can bolt on to it? is there an option for O2 Sensor bungs at an extra charge?
Thanks in advanced.
E
Thanks in advanced.
E
- Ephry73
Jake,
Now that I have a potential buyer for the 2270. I have parts to build a 2 liter just for driving around. Would you recommend I go with a 71mm crank with type 1 journals from your store and no CW, or just a balanced 71mm stock one and stock rods? I have a decent set of heads that have been reworked. I will use a camshaft like a Web 73 or anything you recommend. Do you sale the flanges separately to allow the buyers to make their own system as well?(muffler to header mounting flange)
Thanks in advanced.
E
Thanks in advanced.
E
- Ephry73
Cool. SO far I have tallied up all the parts that I will need to purchase from your store, including the econo header and falls well within my budget, and a whole lot cheaper than rebuilding the type 1 that came with the Ghia.
I will send you an email tonight, and hopefully you can tell me what I have noted wrong, or should change or add.
Thanks a million Jake,
E
E
- Ephry73
Sweet. You have a PM with more or less what I plan to do.
Again, if you feel I need to change something, pleae let me know. Right now I cannot afford betterheads than what I have, but it's a definite upgrade for the future. I want to build a stout shortblock, as cheaply and efficient as possible. 2 liters should be plenty for daily driving, and it will keep me in the hobby.
Sincerely,
Ephry
Sincerely,
Ephry
