Econo Header - Fitted! (Picture)
Hi all,
Received my Econo-header and fitted it this weekend. Jake, this has to be the first aftermarket system that I have ever bought that actually fits without modification! Excellent workmanship.
Couple of questions, do you recommend welding the two joints up, or clamping them? Will it be too difficult to remove if I weld them? Also any tips for finding a dual quiet pack to fit that large flange? Most I have seen are much smaller?
KJH
KJH
Looks great! We have received many kudos for the fitting of the system. That took a lot of work to do without the use of stub pipes!
Try a local muffler shop once the engine is fitted and see what they can cook up for you. If all else fails the muff set up from the A-1 also fits that flange and in the car perfectly and we sell'em separately.
