oil system question...
hberwald
Post by hberwald »
OK I need to add an external oil cooler.
I know what I want to do up front for a cooler and lines.
my question.
Should I eliminate the stock cooler?
should I go with a full flow system
SHould I go with a remote filter
I will add a thermostat to the oil line.
Does Jake have all the parts I need?
so many questions, so little time....
I do still need the barrel spacers. Thanks for the call....
herb
dstar
Post by dstar »
IF you are running lines all the way up front, the full flow is the way to go.
Get rid of the stock cooler and filter setup.
That filter setup is the most restrictive part of the oil flow path!
Don
Post by MASSIVE TYPE IV »
I have everything except the thermostat...
Full flow is the way to go for sure..
The shims should be done by mid next week, we go back to full capacity on Monday when everyone returns from vacation.
hberwald
Post by hberwald »
can you add all the stuff I need to my order?
Should I send an email to follow up?
I want it all!!! :wink:
dstar
Post by dstar »
hberwald wrote: I want it all!!! :wink:
:lol:
Don
Email Rebecca.... I don't work in the parts store much at all, I'm always in the engine shop, so i'm the least effective person to alter the order..
apokrandt
Post by apokrandt »
I have a somewhat related question. At least it deals with the oil system.
I was thinking about replacing the rubber lines that go to Oil cooler located in the DTM with a stainless steel or aluminum hard line.
Do you think this is a bad idea?
I don’t think that the lines need to be flexible because the cooler is in a fixed point to the motor.
The reason I was thinking about replacing them is that it is one less place to spring a leak and I am doing some re-plumbing of the gas and oil lines.
Andrew
apokrandt
Post by apokrandt »
I feel so ignored…..
NO_H2O
Post by NO_H2O »
I think ridged lines would be a bad idea. Viberation/flex would crack them.
bongofarmer
Post by bongofarmer »
I found some info and email contct on this in the 912 regeistry in technical info / oil coolers. some personal stories represented, considering the weak link issues. bongofarmer
hberwald
Post by hberwald »
So, what parts are needed to go to Full flow?
I am also considering external filtration also....anyone got a list?
http://www.aircooledtechnology.com/stor ... 255&page=1
Other than this kit IN A 914 all you'll need are your preferential hoses and fittings and a small bit of work done to the upper left corner of the left side engine mount.
hberwald
Post by hberwald »
Now thats what I am talking about...a kit!!
Thanks, Jake...
Locked
