Greeting all,I'm having a strange sucking sound from my stock 2.0 Type 4 . I travelled a few evenings ago to a location that was 10 miles of almost 45 deg hills . When i was about to shut down and i turned the key off the engine "dieseled". After i restarted some 5 min later, I have this shelly sucking sound coming from the engine. Thought it was the alternator bearing, took the belt and the sound is still there. There is oil right up to the full indicator on the dipstick. I checked the intake silicone boots to see if they are leaking and they are fine. What could be the problem?
will take any suggestions.
Strange Sound?
- dstar
Strange Sound
Hi Dstar, I am using a dbl barell webber carb. This has 4 silicone boots on the intake system. beyond this the "sucking sound" dies out when i put the pedal to the metal but once i let off the gas it raises it's ugly head. Hope that i could describe it as best as i could. Cheers!!!
