DIY Brake Lines
Moderator: tryout
Clatter
DIY Brake Lines
Post by Clatter » Wed Nov 08, 2017 4:22 pm
My project is at the point where it makes sense to just fab up all of the hard brake lines..
Because I'm using certain factory pieces, like master cylinder and calipers, etc.
What is the standard for these old VWs when it comes to brake lines?
Here,
Where I usually order, Eastwood, they list 3/16" and 1/4".
But ain't ours metric?
I have a couple of different benders and a straightener and flare tool and cutter and..
Who has a favorite, or things to avoid?
What about steel vs. stainless, vs. copper nickel?
http://search.eastwood.com/search?w=brake+line
- Doug Ellsworth
SCOTTRODS
Re: DIY Brake Lines
Post by SCOTTRODS » Thu Nov 09, 2017 7:48 am
Stainless is my go to, but I always used Pre fitted lines... haven't done any VW's in MANY years as I haven't had to, so nothing stands out as to do or not to do really in my mind. Others will chime in I'm sure.
UKLuke72
Re: DIY Brake Lines
Post by UKLuke72 » Fri Nov 10, 2017 6:58 am
Stainless work hardens no?
Just use Cunifer. It's made for the job.
M10x1 male fittings
SCOTTRODS
Re: DIY Brake Lines
Post by SCOTTRODS » Fri Nov 10, 2017 7:34 am
All Metals work harden... Stainless faster, but typically you're not likely to do enough working of a brake line to cause fractures unless you have no plan going in. But the typical Lines and materials are fine, I just like the Stainless especially in the long line front to rear to cut down on outside issues of corrosion eating through the line over time. The Cunifer Claims Rust resistance so Sounds like a great place to start as well.
