Black Iron Pipe
MNAirHead
Black Iron Pipe
Post by MNAirHead »
Howdy.
I have a crazy question about black iron pipe...
Can you weld black iron pipe?
I've thought of using it for some brush bars.... mostly show.
T.
Honda's Killer
Post by Honda's Killer »
Im no welding expert, but I herd you cant weld cast iron. It wont stick
CompTurbo.com, Lucas Oil, Pacific Customs,
the_porch_honkey
Post by the_porch_honkey »
You can weld cast iron, but, there is special rod to use(arc welding) and a pre-heating and post-heating process you have to go through also.
If by chance you're reffering to that "black" metal pipe that you would use for gas lines in a house then yes you can weld that with out any special tricks.
MNAirHead
Post by MNAirHead »
Would I be a total idiot if I used the Black Gas Pipe for brush bars and tree bars (street use ony)
I'd rather ask a dumb question than repeat someone's stupid experiment.
Thanks for the smarts.
T.
Puck
Post by Puck »
If you are talking about Sch 40 pipe then yes, you can weld it. It does have a coating on it that needs to be ground off first. It is not made out of cast iron. It is steel.
INSAYN
Post by INSAYN »
Crazy idea indeed! Just use tubing - there is no cost advantage to using pipe for the job of tubing.
INSAYN
