Type 4 engine parts - updated
Moderators: Daniel G, david58
bradey bunch
Post by bradey bunch » Sat Nov 11, 2017 6:52 pm
Hi,
I have the following for sale, send me a PM with your email and I can send photos. Prices in USD, shipping separate.
Everything is new unused, although may show handling marks due to mocking up.
KEP conversion flywheel- $150
Camshaft, 254* @ .050", 112* lobe separation angle - SOLD
Pauter Rods, 136mm length, 22mm pin, type 4 1.7L journal - $500
Type 4 heads, done by brothers machine 42x36mm valves, relocated 12mm plugs, 56cc chambers, dual springs (need to be shimmed to your cam and rocker setup) bored for 94mm jugs - SOLD
Counterweighted 66mm crank done by DPR, .010" under - $250
Pauter 1.48:1 rockers - $500
2 sets of straight cut cam gears - Scat - $75 Magnum - $150
I also have a few type 1 parts I was planning on using for this build, like a 200mm stage 2 kennedy pressure plate, copperhead clutch disc, a bug tech shorty shifter, and 94mm JE pistons with rings, pins, buttons etc listed in the type 1 section.
Braden
Last edited by bradey bunch on Thu Nov 16, 2017 10:45 am, edited 5 times in total.
Re: Type 4 engine parts
Post by Piledriver » Sat Nov 11, 2017 7:56 pm
Are the heads $400 for the pair or each? 1700 castings?
Is the cam a Webcam 163 or something else?
_thesatanicmechanic
Post by _thesatanicmechanic » Sat Nov 11, 2017 8:19 pm
Following up after Piledriver.
Casting# on the heads?
Web 86a cam? got a pic of the snout?
I'm interested in the cam. need a couple more details plz.
bradey bunch
Post by bradey bunch » Sun Nov 12, 2017 5:32 pm
1700 castings from a type 4 if i remember right. For the pair, sold as is. The work was done a few years ago. I have pics of the cam, I need an email address to send to, PM me as per the original post instead of posting it publicly if you'd like.
Braden
bradey bunch
Post by bradey bunch » Mon Nov 13, 2017 2:05 pm
Pulled out the spec sheet for the cam and looked at the stampings - Steve Long XR296 cam 254*@ .050", .366" lift.
And the rod specs: C to C length 5.354"
Big end weight: 436g
Overall weight 627g
Small end diameter .8667"
Big end diameter 2.2755"
Big end width 1.015"
Small end width .995"
Material: E4340 Cro mo
