Transmission Pics VW/Non-VW used in bugs, vans, etc.
Moderator: Henryhoehandle
Wally
Post by Wally » Fri Nov 07, 2008 5:22 pm
I have some pics of a 412, 915 and G50 pics. Last two also opened up for if anyone is interested in these?
T4T: Type 4 Turbo engine, under construction
4bkila
Post by 4bkila » Mon Apr 13, 2009 7:19 pm
anyone fitted or seen a renault zf four speed in a manx/baja i'm wanting to do the swap but would like more informed opinions about what's required etc[/img]
ttriebler
Contact:
Re: Transmission Pics VW/Non-VW used in bugs, vans, etc.
Post by ttriebler » Sun Mar 28, 2010 10:21 pm
Subaru 5MT gearbox fitted into type 1 VW pan. Subaru gearbox fitted with reversed ring and pinion to allow fitting in rear engined cars.
More info at http://www.subarugears.com
Standard OEM gears vs reversed gears
Relief on opposite side housing to clear ring gear bolts
Box in type 1 pan with EJ20 engine block
Shifter location, just to the right of original VW shifter
Upside down, showing clearances and engine height increase vs VW box
Mount mock up. Decent triangulated engine mount needs to be made
Close-up of gearbox mount, sandwiched between 2 x poly suspension mounts
Flatfourfool
Post by Flatfourfool » Sat Dec 04, 2010 12:31 am
any one have info of 091 into 70 ghia? can it be done without cuting or welding?
matberry
Re:
Post by matberry » Sat Dec 04, 2010 8:03 am
4bkila wrote:anyone fitted or seen a renault zf four speed in a manx/baja i'm wanting to do the swap but would like more informed opinions about what's required etc[/img]
Better late than never.
The tranny I'm using is a ZF 4 DS-18 (Renault truck 4 speed that aparently started life in the BMW M1). Gear ratios are a bit short even with 31" rubber. It fits without cutting torsions, and a kombi bell housing adapted relatively easily by making an adapter plate.
boxertje
Contact:
Post by boxertje » Thu Oct 27, 2011 3:10 am
ok, more Renault. UN1 transmission(renault 25 V6)Transporter bell house with aluminium adapter. Beetle main drive shaft with steel adapter bushing.
jabcok20
Post by jabcok20 » Wed Dec 19, 2012 10:06 am
boxertje hej do you have more photo with renault boxes in vw beetle? what about rear suspension?
Post by Ol'fogasaurus » Thu Aug 20, 2015 7:03 pm
Thanks Henry. I must have been going too fast and missed it.
